ASUS F541N Bios Request
  • ebyte64
    • Jun 2023
    • 51
    • South Africa
    Good day
    May I please request a bios file for an Asus F541N laptop?
    The board model is X541NA Main Board Rev 2.1
    My problem is that the laptop does switch on but does not show image on screen. All resistances on the coils look good. All coils also have the right voltages.
    I am thinking it is either a bios or the onboard ram that is faulty.
    Please find attached backup of original bios.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12074
    Re: ASUS F541N Bios Request
    Originally posted by ebyte64
    Good day
    Post here photos of QR codes and stickers.
      • 21421
      Good day
      Post the serial number when you ask for help.
      • ebyte64
        • Jun 2023
        • 51
        • South Africa
        My apologies.
        I have read this post regarding o. the Asus laptops. https://www.badcaps.net/forum/showthread.php?t=96604
        tach images of all QRcodes I see and serial numbers. Maybe I am missing something.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12074
          My apologies.
          ASUS Vivobook Max F541NA
          • ebyte64
            • Jun 2023
            • 51
            • South Africa
            Bios worked perfectly. Thank you very much!
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • skurvysyn
              BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
              by skurvysyn
              laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
              original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
              01-08-2025, 04:45 PM
