latitude 5440 la-m401p la-m402p password
  • struart
    • Aug 2022
    • 38
    • Poland
    #61
    It need a bit of heating because of solder under the chip not only on edges. I use flux and hotair it come off after 1.5 min WSON8 chip are pain in a** if youre new to this Dont rush just warm it for some time it will go offjust dont go too hot Its matter of time not temp.
    • ahmed lachtar
      • Aug 2024
      • 5
      • France
      #62
      Too late alerady damaged the chip and the board. Look at the photos :'( :'(
      Can this still be saved ?
      • struart
        • Aug 2022
        • 38
        • Poland
        #63
        Jeez
        Clean motherboard with IPA in first place to see te REAL damage (its not tragic based on this photo) capacitors looks are in place ;P and chips pins are alive sooo....
        About chip hmm its missing one pin on right? Only egde 8 pins are important ;P
        DOnt ever go that hot for soo long make pauses if its tough....
        • ahmed lachtar
          • Aug 2024
          • 5
          • France
          #64
          Yess the chip is missing a PIN on the right. There was a slight circuit imprint that was moved from a PIN but not disconnected. Should I send this to Poland and let an expert handle it ? I saw on Ali Express that you can buy a similar chip but honestly I don't trust my ability to resolder everythting back.
          • struart
            • Aug 2022
            • 38
            • Poland
            #65
            Im far from expert ;P really far.... Im begginer like you but but couple motherboards later
            Resolder is fine if you use low temperature solder so you hotair that chip about 4 seconds and its done...
            And you should practice on some broken motherboards soldering skills to avoid that situations....
            • andrew25
              • Feb 2016
              • 220
              • Malawi
              #66
              help me unlocking same Dell model,
              ST: BJRJFY3
              • rex98
                • Feb 2023
                • 1252
                • Mandaue CEBU, Philippines
                #67
                ST: BJRJFY3
                1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode​
                • vn000023
                  • Oct 2020
                  • 4
                  Dear Team,
                  Could someone help me to reset password locked for Dell Latitude 5440 Service Tag GXCSV3? Motherboard model LA-M401P
                  Thank you so much​
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11373
                  • Viet Nam
                  #69
                  Originally posted by vn000023
                  Dear Team,
                  Thank you so much​
                  Password removed.
                  • vn000023
                    • Oct 2020
                    • 4
                    Originally posted by hoaca388
                    Password removed.
                    Thank you so much! It is working, how do I make donation?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11373
                      • Viet Nam
                      #71
                      Welcome.
                      • ayceur
                        • Mar 2017
                        • 6
                        • TUNISIA
                        #72
                        i need to unlock 5440 la-m401p with svctag 6304SV3
                        Thank you so much!
                        Badcaps Electronics Repair Forum & Schematic Search
                        • rex98
                          • Feb 2023
                          • 1252
                          #73
                          Thank you so much!
                          • ayceur
                            • Mar 2017
                            • 6
                            • TUNISIA
                            #74
                            Thank you so much!
                            • ayceur
                              • Mar 2017
                              • 6
                              • TUNISIA
                              #75
                              I have this problem ME region corrupted?
                              I didn't do a factory reset
                              • ayceur
                                • Mar 2017
                                • 6
                                • TUNISIA
                                #76
                                I don't know how to write in English, I translate, sorry
                                • ayceur
                                  • Mar 2017
                                  • 6
                                  • TUNISIA
                                  #77
                                  I can't access bios
                                  I can't access windows​
                                  • andrew25
                                    • Feb 2016
                                    • 220
                                    • Malawi
                                    #78
                                    Can anybody help me unlock my bios dump, it has admin pw.. LA-M401P
                                    S/T: 4R8BDY3
                                    8FC8 code
                                    • rex98
                                      • Feb 2023
                                      • 1252
                                      #79
                                      S/T: 4R8BDY3
                                      8FC8 code
                                      • ayceur
                                        • Mar 2017
                                        • 6
                                        • TUNISIA
                                        #80
                                        clear and write for ic 1 and 2
                                        the problem is solved
                                        I'm happy​
                                          DELL Latitude 5440 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5440 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5440 boardview and 5440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5440...
                                          09-07-2024, 07:19 AM
