latitude 5440 la-m401p la-m402p password
    It need a bit of heating because of solder under the chip not only on edges. I use flux and hotair it come off after 1.5 min WSON8 chip are pain in a** if youre new to this Dont rush just warm it for some time it will go offjust dont go too hot Its matter of time not temp.
      Too late alerady damaged the chip and the board. Look at the photos :'( :'(
      Can this still be saved ?
        Jeez
        Clean motherboard with IPA in first place to see te REAL damage (its not tragic based on this photo) capacitors looks are in place ;P and chips pins are alive sooo....
        About chip hmm its missing one pin on right? Only egde 8 pins are important ;P
        DOnt ever go that hot for soo long make pauses if its tough....
          Yess the chip is missing a PIN on the right. There was a slight circuit imprint that was moved from a PIN but not disconnected. Should I send this to Poland and let an expert handle it ? I saw on Ali Express that you can buy a similar chip but honestly I don't trust my ability to resolder everythting back.
            Im far from expert ;P really far.... Im begginer like you but but couple motherboards later
            Resolder is fine if you use low temperature solder so you hotair that chip about 4 seconds and its done...
            And you should practice on some broken motherboards soldering skills to avoid that situations....
              help me unlocking same Dell model,
              ST: BJRJFY3
                ST: BJRJFY3
                1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
                  Dear Team,
                  Could someone help me to reset password locked for Dell Latitude 5440 Service Tag GXCSV3? Motherboard model LA-M401P
                  Thank you so much
                  Originally posted by vn000023 View Post
                  Dear Team,
                  Thank you so much
                  Password removed.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Originally posted by hoaca388 View Post
                    Password removed.
                    Thank you so much! It is working, how do I make donation?
                      Welcome.
                        i need to unlock 5440 la-m401p with svctag 6304SV3
                        Thank you so much!
                        Badcaps Electronics Repair Forum & Schematic Search
                          Thank you so much!
                            Thank you so much!
                              I have this problem ME region corrupted?
                              I didn't do a factory reset
                                I don't know how to write in English, I translate, sorry
                                  I can't access bios
                                  I can't access windows
                                    Can anybody help me unlock my bios dump, it has admin pw.. LA-M401P
                                    S/T: 4R8BDY3
                                    8FC8 code
                                      S/T: 4R8BDY3
                                      8FC8 code
                                        clear and write for ic 1 and 2
                                        the problem is solved
                                        I'm happy
