HP OMEN-X 17T-AP000 DA0G3CMBCH0 Rev H
  • questore
    • Dec 2015
    • 577
    • csongrád
    Hi Everyone,
    I need a BIOS for this board in the title! Thanks!
    • 22279
    Re: HP OMEN-X 17T-AP000 DA0G3CMBCH0 Rev H
    Originally posted by questore
    Hi Everyone,
    You must post the serial number and backup,if available.Also post a description of the issue -> https://www.badcaps.net/forum/showthread.php?t=103570
    • questore
      • Dec 2015
      • 577
      • csongrád
      Thank you very much for your instructions.
      Problem description:
      https://www.badcaps.net/forum/showth...87#post1272587
      • questore
        • Dec 2015
        • 577
        • csongrád
        CT: PGWTL018J9300O
        Modell: G3C-N17E-G2
        HP SA: L03430-601
        PN: 10MB8ZZ014B
        940622-601
        31G3CMB00F0 VER: H3B
        The BIOS extracted only has a file size of 1Mb
        Attached the file
        • peste
          • 13924
          • ROMANIA
          CT: PGWTL018J9300O
          Modell: G3C-N17E-G2
          HP SA: L03430-601
          PN: 10MB8ZZ014B
          940622-601
          Attached the file
          you should have another bios chip on the board...search on both sides..and post the content of the chip..
          • questore
            • Dec 2015
            • 577
            • csongrád
            Found it, but I have to modify my ch341A beause it is a 1.8V 25Q40EWNIG.
            Be back when i have the bios content.
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              25Q40EWNIG is not the bios chip either. Inspect the motherboard for it further.
              Become a Badcaps supporter
              Thanks to all supporters.
              • questore
                • Dec 2015
                • 577
                • csongrád
                I dont know how I have missed it, if was full of flux so someone has been playing with it. Here it is:
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  https://www.badcaps.net/forum/showthread.php?t=103526
                  6. Finding bios update packages
                  6.1.8 HP
                  See:
                  [Guide] How to extract ready for programming dump from HP update executable file
                  https://www.badcaps.net/forum/showthread.php?t=121948
                  https://www.badcaps.net/forum/showth...51#post1261151
                  When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
                  DMI: 220000 - 222FFF
                  Win key: 63E000 - 63E03F
                  • uvoll
                    ADBMS6815 full datasheet or SPI register description
                    by uvoll
                    I'm asking this for a friend, he has a backup battery, a quite large unit, that does not
                    work as intended. Even the service techican was not able to solve all problems so far.
                    My friend tried to log the SPI bus, but there is a lot of communication going on.
                    Without any meaningful description on the Ic's internal registers he's quite lost.
                    The datasheet that's avalible for download form Analog Devices is only 2 pages and contains
                    nothing more than a block diagram and a coarse description of the operation.
                    11-20-2023, 09:48 AM
                  • RedLaugh
                    MacBook A2337 820-02899-A need ic description
                    by RedLaugh
                    Hello!
                    I have a MacBook A2337, the motherboard label is 820-02899-A. Laptop after flooding. Please help me identify the part - it is marked with a dot in the photo. Marking on the B3 chip. What kind of chip is this? Is there a dataset or at least a name
                    09-15-2024, 09:48 AM
                  • SuperAman
                    PS5 EDM-010 3 Beeps
                    by SuperAman
                    Getting 3 beeps only when console is plugged into power, no lights. I was thinking a possible NOR issue but the uart codes are leading to something possibly more serious? EDM-010 disk edition. I didn't try clearing the error codes yet, wanted to backup the NOR first, CH341A programmer comes tomorrow.
                    Error code: 80810001
                    Description: General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
                    Error code: C00C0002
                    Description: VRM Controller Failure, Check Mosfet (6414A) Located Side-A, Below Sony Interactive Entertainment Inc. Check Infineon XDPE14286A...
                    09-06-2025, 08:25 PM
                  • rustinjust
                    Please help, subwoofer connected to tv, read description below
                    by rustinjust
                    I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                    Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                    Is there a way of...
                    10-28-2023, 07:09 AM
                  • questore
                    by questore
                    Hi guys,
                    I need a Boardview for this board in the title!
                    Schematic is not realy helpful because there is no any text or marking in the board.
                    Thanks!
                    09-19-2023, 02:22 AM
