Hi., I purchase two ACER ChromeBook C733-C5AS from eBay. Upon turning on I see both are affiliated with school's name, & it's asking for the gmail email & the password, Ofcourse this info I do not have. I have attached the original Locked BIOS Bin file. Is this info written in the BIN files or on the SSD chip??? I use the Bin file from post #12 but did not work. Then I downloaded a fresh BIN file from another site & it worked fine & did do a full factory restore. But the lock condition is the same, No change, asking for email & password. I can try again if the Original BIOS is unlocked. I am assuming this info is written on the SSD chip which cannot be erased, similar to iCloud. Can some put some light on this kind of error. Thanks in advance.
Re: acer chromebook c731 bios
Some Brands you should install new OS after Erollemnt, remove so if Dumped File still have enrollment just, reinstal OS and enjoyHi., I purchase two ACER ChromeBook C733-C5AS from eBay. Upon turning on I see both are affiliated with school's name, & it's asking for the gmail email & the password, Ofcourse this info I do not have. I have attached the original Locked BIOS Bin file. Is this info written in the BIN files or on the SSD chip??? I use the Bin file from post #12 but did not work. Then I downloaded a fresh BIN file from another site & it worked fine & did do a full factory restore. But the lock condition is the same, No change, asking for email & password. I can try again if the Original BIOS is unlocked. I am assuming this info is written on the SSD chip which cannot be erased, similar to iCloud. Can some put some light on this kind of error. Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: ACER ChromeBook C733-C5AS
Check your solder carefully and comment, I will check the bin.Comment
Check and commentsAttached Filesif you find these attachements useful please consider making a small donation to the site
WORKED 100%.. But still geting the same "Enterprise Enrolment" message. I think this is written either in the EC or the SSD Chip. When connect to the net, this message appears right away. Do you have any idea about this message as of where is it generating from??? Restored it twice.... Thanks for all the help.Comment
try this then reinstall from USB stick made with Chromebook Recovery Utility for your model.WORKED 100%.. But still geting the same "Enterprise Enrolment" message. I think this is written either in the EC or the SSD Chip. When connect to the net, this message appears right away. Do you have any idea about this message as of where is it generating from??? Restored it twice.... Thanks for all the help.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
@volinakis., The BIN files which you sent me is not working at all. No Display. Maybe some cleanup required. But the post # 6 working 100% fine but still give the Enterprise Enrollment error. Do you know whether this info is stored on the SSD IC or the EC chip??Comment
check soldering, for sure you didn't solder well chipset.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
@volinakis I checked the 8 pins carefully & infact this is the 5th time I am soldering the chip. The contact are 100% good, trust me & I even used a iron to solder on the pins. Since this did not work I used the BIN on post #6. Boom all worked fine, but the error still exists. Do you think this BOM info is on the 32GB SSD? what you think? other than this error Laptop is working fine.Comment
Hi @volinakis, the Bin file which send me is working too, accidentally without knowing I programmed the bin file on a 3.3v BIOS chip whereas this had to be programmed on a 1.8V chip. All works fine but the "Enterprise Enrolment" error message is still there. Might have to replace the SSD chip. Thank you guys for all your help.Comment
it should work if you REINSTALL from USB stick made for your model: Acer Chromebook 311 (C733, C733U, C733T)Hi @volinakis, the Bin file which send me is working too, accidentally without knowing I programmed the bin file on a 3.3v BIOS chip whereas this had to be programmed on a 1.8V chip. All works fine but the "Enterprise Enrolment" error message is still there. Might have to replace the SSD chip. Thank you guys for all your help.Attached Filesif you find these attachements useful please consider making a small donation to the site
This specification for the Acer Chromebook C731-C6R5 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C731-C6R5 boardview and C731-C6R5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 04:10 PM
This specification for the Acer Chromebook C731-C55U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C731-C55U boardview and C731-C55U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 04:10 PM
This specification for the Acer Chromebook C731-C07G Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C731-C07G boardview and C731-C07G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 11:32 AM
This specification for the Acer Chromebook C731-C118 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C731-C118 boardview and C731-C118 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 07:33 AM
This specification for the Acer Chromebook C731-C88W Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C731-C88W boardview and C731-C88W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 07:33 AM
- Loading...
