Dell Latitude 3590 BIOS dump request
  • owegner75
    • Jul 2023
    • 5
    Heya, I'm looking to reflash the BIOS on a Dell Latitude 3590 P75F001 (Service tag: 1HBSDP2). Does anyone have the BIOS for this laptop?
    Additionally, I'm not 100% sure I've properly located the BIOS chip. I've found a chip marked as 'UC3' on the mobo, which is labelled as 'WINBOND 25Q128JVSQ 1748' and located right next to where the touch pad's ribbon cable connects to the mobo (see pic). If anyone can verify that this is in fact the correct chip that would be wonderful.
  • owegner75
    • Jul 2023
    • 5
    Re: Dell Latitude 3590 BIOS dump request and BIOS chip location verification
    For clarification, the board is: CAL50/DAL10 LA-F115P and rev: 1.0 (A00), and the full service code is 1HBSDP2-E7A8
    • hardware1
      • Sep 2021
      • 2926
      • N/A
      Additionally, I'm not 100% sure I've properly located the BIOS chip. I've found a chip marked as 'UC3' on the mobo, which is labelled as 'WINBOND 25Q128JVSQ.
      Yes, "25Q128JVSQ" is the right one. What is the problem with your device or what you want to do?
      If your issue is a BIOS Password, you can use this site.
      https://beta.bios-pw.org/
      all donations are welcome,
      • owegner75
        • Jul 2023
        • 5
        Awesome, thanks for the clarification. The issue is password related, but I've tried both that site and a number of others to no avail. I've tried the CTRL+ENTER+ENTER trick, CTRL+ENTER, and a variety of others (like removing the CMOS battery, for example) with no success.
        A few other sites have suggested that machines with the -E7A8 and -8FC8 suffixes may not work with password recovery sites, which seems to be the case for me. As this is a laptop I bought for parts and paid next to nothing for - and one that I will be parting out if it remains bricked - I figured it would be a good candidate for learning to reflash a BIOS (via a CH341 programmer & test clip) as I have little to lose should things go sideways.
        • hardware1
          • Sep 2021
          • 2926
          • N/A
          E7A8 can work fine with the master generator password, you need to be careful with upper/lowercase letters and use an external (QWERTY) US Keyboard.
          If it still doesn't work, you can upload your BIOS file here and someone will help you.
          • owegner75
            • Jul 2023
            • 5
            [QUOTE=hardware1;1258510]E7A8 can work fine with the master generator password, you need to be careful with upper/lowercase letters and use an external (QWERTY) US Keyboard.
            I've tried this as well, and nothing.
            • ahmarzo
              • Mar 2015
              • 170
              • india
              Latitude 3590 la-f115p bios request
              have la-f115p bios correpted after online update .dell logo comes and laptop shutsdown.service tag is 2SYWDP2 have attached the backup bios.
              Last edited by SMDFlea; 09-02-2023, 04:29 AM. Reason: Added "Latitude 3590" to thread title
              • hoaca388
                Badcaps
                • Jan 2022
                • 11640
                Re: Latitude 3590 la-f115p bios request
                Latitude 3590
                • maybel
                  • Dec 2017
                  • 24
                  • philippines
                  try this
                  • Vataco
                    • Feb 2022
                    • 8
                    • Venezuela
                    Greetings everyone, I have a Dell Latitude 3590 laptop with a CAL50/DAL10 LA-F116P REV:1.0 motherboard and BIOS version 1.26. The problem is that it has no audio. I have already tried everything related to the audio drivers and even checked the physical status of the audio processor and it is in good condition, powered and enabled. I would like to reinstall BIOS 1.26 or an earlier one. I cannot do it by .exe file because Dell does not allow the upgrade to be downloaded.
                    • Bios Cracker
                      • Oct 2024
                      • 312
                      • India
                      Attach your original dump file.
                        • 20673
                        Thread merged. Read https://www.badcaps.net/forum/troubl...before-posting and post your service tag and backups
                        • metlj
                          Mehdi
                          • Jan 2023
                          • 18
                          • america
                          Latitude 3590
                          thnks bro works 100%
                          • mat.miwa
                            • Dec 2019
                            • 17
                            • Киргизия
                            help with bios Dell Latitude 3590
                            CAL50/DAL10 LA-F115P REV:1.0 (A00) 2017-09-26
                            ST:77LYDP2
                            old bios included
                              • 20673
                              ST:77LYDP2
                              old bios included​
                              Explain what the problem is , no boot, password etc.
                              • mat.miwa
                                • Dec 2019
                                • 17
                                • Киргизия
                                no initialization, all main power supplies are present, nothing on the display
                                • Echoo
                                  • Apr 2018
                                  • 83
                                  • Budapest
                                  Hello!
                                  I have a Dell Latitude 3590, which does not give a picture, only the fan spins at maximum and the caps lock key lights up. According to the owner, it restarted after a windows update, and since then there has been no picture. Please, if anyone knows how to do this, take a look at this file, maybe the laptop can be saved!
                                  Dell Latitude 3590
                                  ST: GZB3LP2​
                                  • shiyab
                                    • Sep 2023
                                    • 1321
                                    • india
                                    Originally posted by Echoo
                                    Hello!
                                    Dell Latitude 3590
                                    ST: GZB3LP2​
                                    hi try
                                    • Echoo
                                      • Apr 2018
                                      • 83
                                      • Budapest
                                      Originally posted by shiyab
                                      hi try
                                      Unfortunately it has remained unchanged. There is no picture, the fan is spinning at maximum.
                                      • Zillions Tech
                                        • Jul 2022
                                        • 22
                                        • Nigeria
                                        Please i need a clear ME Bin for my system the keyboard is malfunctioning and i have changed new
                                        keyboard still doing the same thing i will attach my original bin here
                                        Board ID: LA-F115P
                                        S/TAG: GYQ8FP2
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 3590 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3590 boardview and 3590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3590...
                                          09-06-2024, 12:36 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                          09-06-2024, 09:23 AM
