hp chromebook 14 G7 bin FILE REQUEST Please
  • KABY
    • Dec 2022
    • 71
    • algeria
    can someone help me with this particular problem?
    this is the ORIGINAL bin file of my chromebook 14 G7
    with dev mode blocked and enterprise enrolment on!
    can someone help me with this! bypass admin restriction?
    or someone have original bin file from HP website
    motherbord is tmt yaml 1994V-0 E114139
    thanks for help
  • KABY
    • Dec 2022
    • 71
    • algeria
    Re: hp chromebook 14 G7 bin FILE REQUEST PLZ
    Update im waiting for miracle my chromebook still off without bios any help please
    The origin bios have enrollments and dev mode blocked ��
    I tried everything it still nothing
    Please help
    • rex98
      • Feb 2023
      • 1293
      • Mandaue CEBU, Philippines
      try this. first boot open dev mode then powerwash.
      • KABY
        • Dec 2022
        • 71
        • algeria
        i have tried this technique nothing happens maybe. i miss something !!!
        always devmode blocked after 5 attempt the laptop turn off
        sometime keep showing that h is in dev mode but no general access to all option.
        maybe this bios is corrupted!!!
        • volinakis
          • Jan 2021
          • 2874
          • N/A
          try this bios then REINSTALL using USB stick made with Chromebook Recovery Utility for your model.
          • KABY
            • Dec 2022
            • 71
            • algeria
            With this bios hp don't boot
            • KABY
              • Dec 2022
              • 71
              • algeria
              • KABY
                • Dec 2022
                • 71
                • algeria
                This is message a geti can't access every time I try
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  sure, learn to solder chipset ...
                  • KABY
                    • Dec 2022
                    • 71
                    • algeria
                    It's done with rcunlocker
                    For the soldering I'm perfect on it
                    I will post the bios
                    And thank you for helping me
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      with RCUnlocker was made Rex's file ...
                      with my file it should work, done several G7s ...
                      when somebody say's "I'm perfect" ... well ... run!
                      • KABY
                        • Dec 2022
                        • 71
                        • algeria
                        Sorry sir but laptop didn't start
                        You have made 2 changes dev and enrollments and you replace other address when it comes to bios I don't know anything for sur
                        But soldering I even rework bga chips
                        • rachidell
                          • Aug 2016
                          • 140
                          • algeria
                          can you give the bios file
                          thank you
                          • xemix218 (xemix218)
                            • Dec 2024
                            • 11
                            • México
                            I have the same model of laptop, could you send the bin file (bios) that you used to unlock? or the steps you took to unlock the bios with rcunlocker?
                            • peste
                              • Dec 2016
                              • 13678
                              • ROMANIA
                              post the S/N, post the original content of the bios chip, the motherboard model, the full name and model of the laptop,etc.
                                • Dec 2024
                                • 11
                                • México
                                HP Chromebook 14 G7
                                S/N:5CD408BOF4
                                MB Model: DA00GLMB6I0
                                • lint4u
                                  • Nov 2013
                                  • 126
                                  • lint4u
                                  HP Chromebook 14 G7
                                  S/N:5CD408BOF4
                                  Try this one and re-install using USB stick
                                    • Dec 2024
                                    • 11
                                    • México
                                    I just tried it and restored it with a memory stick, but enrollment still hasn't been unlocked.
                                      • Dec 2024
                                      • 11
                                      • México
                                      Forget it, I already tried to flash again and I was able to enter normally and it seems that it is now unlocked, thank you very much for the help!
                                      • lint4u
                                        • Nov 2013
                                        • 126
                                        • lint4u
                                        You're wellcome
                                        Thanks for feedback.....glad to hear that
                                        BR
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • 247
                                          [Request] BIOS file for Medion Akoya S6445 (MD61280)
                                          by 247
                                          I'm looking for the original BIOS file for the Medion Akoya S6445 – model MD61280, preferably in .bin or .rom format for flashing via CH341A programmer.
                                          The BIOS chip is a GStek GS7166 (25Q64 compatible, 8MB SPI).
                                          Does anyone have the correct BIOS file or know where to get it?
                                          Any help would be greatly appreciated!
                                          Thanks!
                                          04-08-2025, 11:08 AM
                                        • ianhaney
                                          HP Pavilion DV2130ea bios bin file request
                                          by ianhaney
                                          I am new to the forum and looking for a HP Pavilion DV2130ea bios bin file. I can't seem to find one online, I can only find a exe file
                                          02-16-2025, 08:14 AM
                                        • slugpoa
                                          Bios Chromebook Positivo - N2312 ROHS - Q01-63875-V2.0 Request
                                          by slugpoa
                                          Bom dia, preciso de ajuda com a Bios bloqueada
                                          Fabricante: Positivo
                                          Modelo: N2312 ROHS ,
                                          S/n: 4AG850Q6D
                                          Modelo PLACA: Q01-63875-V2.0
                                          Agradeço desde já .
                                          Today, 04:10 PM
                                          Good morning, I need help with the blocked Bios
                                          Manufacturer: Positivo
                                          Model: N2312 ROHS,
                                          S/n: 4AG850Q6D
                                          BOARD Model: Q01-63875-V2.0
                                          Thank you in advance.​
                                          in English please.....
                                          11-25-2024, 08:10 AM
