Macbook A1706 EFI removal
  • keats11
    • Nov 2012
    • 88
    I have a macbook A7106 model with an EFI lock on it. I am resonably good at micro soldering, so I removed the BIOS chip and removed the "password section" which is the block of code following the "$SVS" token. There are two such instances in the BIOS. More specifically between addresses
    :a) 15B050 -> 15B850 b) 15D050 -> 168FF0. After putting the updated BIOS back, I get a folder with "?". Tried doing MacOS recovery when it says "Recovery Server Could not be Contacted". I did this like 25 times so I know it doesn't work. I have Wifi and also have a wired ethernet adapter. It doesnt work with either. Does anyone know the complete process for removing the EFI lock? I am worried all the connectors will break before I try out a hundred different things.
    • 22135
    Re: Macbook A1706 EFI removal
    EMC number ? , Serial number ? , bios backup ?
    • keats11
      • Nov 2012
      • 88
      Serial: C02W56SZHV2L
      Board: 820-00239
      Attached BIOS (unmodified)
      • peste
        • 13779
        • ROMANIA
        Board: 820-00239
        try..
        • keats11
          • Nov 2012
          • 88
          I tried flashing this just now. Same result. It comes with the recovery screen, when I say install macOs Sierra, it thinks for a minute and says "recovery server could not be contacted". Wish there was way to debug this rather than guess. I also had a USB boot that my wife says she had created onetime. Not sure if that would work.
          • ibo
            • Oct 2019
            • 107
            • Turkiye
            So efi password is gone, now you have trouble with installing new OS.
            If new install doesnt work with wifi then try with a usb stick
            • cmn.fix
              • 41
              Hello! I need help with unlocking the EFI password on a MacBook A1706 EMC 3071 S.N. C02T10CDGTDX. Thank you in advance!
              • peste
                • 13779
                • ROMANIA
                try..
                • cmn.fix
                  • 41
                  Originally posted by peste
                  try..
                  Worked like a charm. Multumesc!
                  • aldodavilam
                    • Mar 2020
                    • Estados Unidos
                    Hello good friends of this wonderful community, I have an A1706, and I want to remove the EFI password, since when I try to reinstall the system, the little padlock appears. I intend to do what our friend did in the first post about the $SVS token. However, I see that in the different instances of the BIOS backup I make, it always changes and is not identical as in other cases. Even if I change it, it will continue to work the same. That's my question. ?
                    Best regards to everyone.​
                    • peste
                      • 13779
                      • ROMANIA
                      post S/N, full name and model, motherboard model, ,EMC,etc.
                      post the original contents of the bios chip..
                      • iAM_TM
                        • Mar 2025
                        As in sent message:
                        EFI password NEVER set. PLEASE HELP.
                        MacBook Pro, 2017
                        Model: A1706
                        EMC: 3163
                        Serial Number: C02WT0GJHV2R
                        Motherboard and Amtel chip: C02821 500G WHRQH1 C36A7D9A4B765F995
                        Thanks again
                        AM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • Danielreinaa
                          HELP need password bios Macbook A1706
                          by Danielreinaa
                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                          09-07-2024, 03:47 PM
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
