Legion 5 pro nm-d562 rev 2.0
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    I have legion 5 pro amd ryzen 7 nvidia rtx,,,
    i suscpected 1st it is bios problem because at first the bios ic cant be verify by any of my rtl09 ezp and ch431,, using its 1.8v adapter,,,
    i already purchased new bios ic 16mb 1.8v but different brand,, now it can be verify using 1.8v adapter,, but still no display,,,
    do other experienced same problem,, in my mind maybe it is via bios ic compatibility,, or board component problem,, or my bios creator failed to create new good one
    i attached my back up file,, and my created file,,,
    • 21907
    Re: Legion 5 pro nm-d562 rev 2.0
    Post the laptop serial number,and FULL laptop model number.
    • Marc97
      • Jan 2016
      • 189
      • Phillipines
      thanks for reply,,, the file is good,, i just seen it now that the prroblem is the flex cable,,,
      good file (the 2nd) name created from website GKCN60WW,,
      THANK YOU,,, smdflea
      tested good
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        i am wiiling to donate,,, soon,, my account only is GCASH,,, no paypal yet
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • nissimezra
          Lenovo Legion 9 16IRX8 NM-B481 rev 1.0 bios bin file
          by nissimezra
          Device: Laptop
          Brand: Lenovo
          Model: Legion 9 16IRX8 - Type 83AG
          Service Tag: PF4M4H2J
          Board number: NM-B481 rev 1.0 bios bin file
          Request: BIOS dump
          Problem: Black screen
          The bios chip is 25rh256cxiq , can I use winbound 25q256... instead ?
          thanks in advanced...
          05-29-2025, 04:07 PM
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
          07-23-2023, 07:39 AM
