Legion 5 pro nm-d562 rev 2.0
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    I have legion 5 pro amd ryzen 7 nvidia rtx,,,
    i suscpected 1st it is bios problem because at first the bios ic cant be verify by any of my rtl09 ezp and ch431,, using its 1.8v adapter,,,
    i already purchased new bios ic 16mb 1.8v but different brand,, now it can be verify using 1.8v adapter,, but still no display,,,
    do other experienced same problem,, in my mind maybe it is via bios ic compatibility,, or board component problem,, or my bios creator failed to create new good one
    i attached my back up file,, and my created file,,,
    • 22127
    Re: Legion 5 pro nm-d562 rev 2.0
    Post the laptop serial number,and FULL laptop model number.
    • Marc97
      • Jan 2016
      • 189
      • Phillipines
      thanks for reply,,, the file is good,, i just seen it now that the prroblem is the flex cable,,,
      good file (the 2nd) name created from website GKCN60WW,,
      THANK YOU,,, smdflea
      tested good
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        i am wiiling to donate,,, soon,, my account only is GCASH,,, no paypal yet
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • nissimezra
          Lenovo Legion 9 16IRX8 NM-B481 rev 1.0 bios bin file
          by nissimezra
          Device: Laptop
          Brand: Lenovo
          Model: Legion 9 16IRX8 - Type 83AG
          Service Tag: PF4M4H2J
          Board number: NM-B481 rev 1.0 bios bin file
          Request: BIOS dump
          Problem: Black screen
          The bios chip is 25rh256cxiq , can I use winbound 25q256... instead ?
          thanks in advanced...
          05-29-2025, 04:07 PM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
