Chuwi Herobook Pro
  • kulokutoys
    • Jun 2010
    • 132
    • Phillippines
    Chuwi Herobook Pro
    Inet-x3123 rev10
    turns on then off all of a sudden. can someone clean me on this bin. thanks
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Chuwi Herobook Pro
    Originally posted by kulokutoys
    Inet-x3123 rev10
    post the full name and model, S/N, etc.
    • kulokutoys
      • Jun 2010
      • 132
      • Phillippines
      HeroBP256G210702861
      Inet-x3123 rev10
      this is all I got.
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        HeroBP256G210702861
        Inet-x3123 rev10
        this is all I got.
        TRY this file,,,
        if not,,, try to switch it on without keyboard,, or remove keyboard flex cable on main board,,, switch it on to the terminal keyboard flex port to main board,,, switch located last pin on right side and its terminal beside on it,,, sometimes it has arrow logo on mainboard
        • kulokutoys
          • Jun 2010
          • 132
          • Phillippines
          thanks but I don't have the unit anymore. your bin will be useful for feature use
          • nafienew
            Chuwi HeroBook TYPE CWI514 No display
            by nafienew
            Board: In - SE115C_VD3
            HeroBook64G191109037
            NO DESPLY...
            10-18-2024, 06:10 AM
          • qellu
            Chuwi HeroBook Plus CWI530 bios request
            by qellu
            Hello, please check the BIOS in the Chuwi HeroBook Plus CWI530 laptop, the X133G rev. board designation. x1.0.
            laptop does not start with basic voltage present.
            dump in attachment...
            10-27-2023, 08:38 AM
          • Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
            by Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
            03-15-2024, 09:37 AM
          • minuccio88
            Chuwi Herobook Pro bios password
            by minuccio88
            I have a Herobook Pro JHeroBP256G201010862, the motherboard is X133GRX170-G60E.
            When i turn on the laptop there is a bios password request, someone can help me? I need or a bios dump or a bios unlocked
            I attached some photo and also the bios locked
            Thanks so much...
            01-11-2023, 09:28 AM
          • www
            LG L192WS-BN backlight turns off after 1 second
            by www
            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
            03-24-2024, 05:26 PM
