CSME System Tools Error
  • Inforgalaxie
    • Apr 2023
    • 39
    • Portugal
    Hello, when i open the CSME System Tools v11 I have this error:
    Unable to parse vsccommn.bin at C:/User/Ambiente de Trabalho/CSME System Tools v11 r41/Flash Image Tool/WIN32/vsccommn.bin
    How I can solve this problem? Because My ME region is version 11
    What this error can be? I try another version 11 and i have the same error...
    Family: CSE ME
    Version: 11.0.12.1008
    SKU: Corporate LP
    Chipset: SPT/KBP-LP C
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: CSME System Tools Error
    Family: CSE ME
    SKU: Corporate LP
    Upload your BIOS Backup here, write some information about your device and describe your device problem.
    all donations are welcome,
      • 22279
      Family: CSE ME
      SKU: Corporate LP
      Make a new folder on your desktop,name it anything you want but it must only have only english letters (not letters like ÇÃ).Move all the contents of the FIT folder into the new one (fit.exe ,newfiletmpl.xml ,vsccommn.bin) .Rename your bios backup with english letters and put it in the same folder. Try it, if it doesn`t work move the folder to the C drive and try it from there.
      • Inforprint
        • Apr 2016
        • 65
        • Brasil
        Great!!
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • sushilachuthan
          APC UPS error P13
          by sushilachuthan
          one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
          the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
          The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
          We replaced the SCR with new device,, but the device is not power on as expected.
          Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
          09-26-2025, 09:00 AM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Maalobs
          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
          by Maalobs
          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
          The relevant service manual for the chassis is available here.
          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
          When I short the SDM to ground I get the layer-2 error code 53.
          The inside of the TV has no damaged components and no swollen capacitors.
          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
          04-02-2019, 01:15 PM
