6-77-n850hj10-d02b BIOS Need
  • neurevt
    • Jun 2021
    • 14
    • Norway
    Hi everyone!
    6-77-n850hj10-d02b-15D#10 i need bios file. Thank you.
    N850HJMB-0D
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: 6-77-n850hj10-d02b BIOS Need
    Originally posted by neurevt
    Hi everyone!
    Read the rules before posting:
    https://www.badcaps.net/forum/showthread.php?t=72302
    http://repo.palkeo.com/clevo-mirror/
    User:repo
    Pass:repo
    Become a Badcaps supporter
    Thanks to all supporters.​
    • neurevt
      • Jun 2021
      • 14
      • Norway
      Thanks for reply my message. But this site don't find my bios file
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        It's there, you're just too lazy to scroll a bit and find it.
        I also gave you a link to a topic here in the forum.
        • neurevt
          • Jun 2021
          • 14
          • Norway
          Not work bro. The motherboard codes in the thread you sent are different. My main BIOS is image coming.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            First of all I'm not "bro", if you want to address me use or my nickname.
            Secondly there's no need to explain me about the motherboard codes and so on, I've checked all the necessary things beforehand so just flash the SMDFlea's dump (bios version 1.05.19) at the linked topic, that's it. Or use the Clevo mirror link and download the dump for your machine as I already said (your bios version is 1.05.15, latest available is version 1.05.22).
            And third (again) read the rules. Add make and model name to the thread title, also serial number and issue description to the post.
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • Forest79
              by Forest79
              07-23-2023, 07:39 AM
