i need a help unlock 645 g9
  • hirens
    • May 2022
    • 186
    • uganda
    #81
    Originally posted by hirens
    hello guyz i have an hp elitebook 645 G9
    i got it when both chips are missing
    kindly provide me with new files because i have the flat chips with me
    i will re-program afresh
    thanks
    HP ELITEBOOK 645 G9
    S:N_5CD3029XJJ
    PRD ID: 724B0EA#ABU
    Board No_ DA0X9SMB8D0 REV
    any help yet
    • Kodza
      • Jun 2016
      • 194
      • South Africa
      #82
      Hi I need Help to remove password on HP EliteBook 645 G9, S/N 5CD243HVQQ. I have uploaded both ec and main bios.
      Thank you
      • rex98
        • Feb 2023
        • 1293
        • Mandaue CEBU, Philippines
        #83
        I noticed there's a lot of unlock request for this model HP EliteBook 645/655 14/15.6 inch G9
        The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you shouldFlash Both.
        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
        use BCU and put your original DMI
        This bios is extracted from hp website so its fast boot this would work in two models 14 and 15 inch they have the same bios.
        To determine your BID use any hex editor and search for the BID. Ex: U77
        frequently asked questions:
        can i use this to my HP EliteBook 645/655 14/15.6 inch G9- yes
        This is the both BID U77 and U87 its all you need.​
        • Kodza
          • Jun 2016
          • 194
          • South Africa
          #84
          Thank you Rex I hope it will help a lot of other guys
          • MonkeydBrianZA
            • Dec 2021
            • 4
            • south africa
            #85
            Please unlock mine got administrator password
            HP EliteBook 645 G9
            SN# 5CD2471XBC
            ProdID 6J5H9AV
          • ilias kalle
            • May 2024
            • 16
            • SWEDN
            #86
            HP EliteBook 645 g9 unlock
            5CD3085B3Y
            • clemence
              • Jun 2013
              • 23
              • zimbabwe
              #87
              Please i need help, i got HP EliteBook 645 G9 AMD Ryzen. its not intel processor
              Product ID: 766R9UC#ACQ
              Serial number: 5CD243HVQS
              Motherboard: DA0X9SMB8D1 REV: D MODEL: X9S
              I NEED MAIN BIOS BIN & EC.
              I have made a backup file. i have tried some bin files posted here but nothing works what i have noticed is that most files are for intel processor. i also download bios update from HP site but i am failing to extract the bin files can someone help pliz. With original file the fan spins and processors warms normal but black screen. when i try some bin files posted here some only blink caps lock only 5 times but it does turn on or spin fan.
            • nafienew
              • Aug 2014
              • 113
              • up
              #88
              HP EliteBook 645 G9
              SN 5CD3172XW5
              • LBTT1121
                • Nov 2024
                • 964
                • Việt Nam
                #89
                HP EliteBook 645 G9
                SN 5CD3172XW5
                try post 83 https://www.badcaps.net/forum/troubl...96#post3683596
                • nafienew
                  • Aug 2014
                  • 113
                  • up
                  #90
                  Originally posted by LBTT1121
                  This device is AMD, not Intel, and most of the bios found here are for Intel.
                    • 21889
                    Those are AMD. The 645/655 G9 are AMD models.
                    • nafienew
                      • Aug 2014
                      • 113
                      • up
                      #92
                      I tried it, the device works but there is no image. Can you help me delete the password from the original file? Thank you. SMDFlea
                      HP EliteBook 645 G9
                      SN 5CD3172XW5
                      • nafienew
                        • Aug 2014
                        • 113
                        • up
                        #93
                        Thank you rex98
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • Nopslide
                          by Nopslide
                          04-01-2024, 04:27 PM
                        • outsider
                          Panasonic FZ-G1 MK5 - BIOS password returning
                          by outsider
                          Hello
                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                          https://www.badcaps.net/forum/troubl...61#post3637661
                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                          06-17-2025, 12:51 AM
                        • BlackVisor
                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                          by BlackVisor
                          RedmiBook Pro 1542022 6800H
                          SKU: TM2113-39463
                          Model Number: RMA2204-AB
                          CMIIT ID: 2022AP1835
                          SN: 39463/22WD01355
                          BIOS version: RMARB5B0P1010 20230628
                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                          01-14-2024, 06:35 AM
                        • RMDUiFT
                          Should I buy a Lenovo Thinkpad E495 with bios password?
                          by RMDUiFT
                          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                          I have a few questions:
                          • If I would buy this laptop and have
                          08-25-2024, 09:00 AM
