i need a help unlock 645 g9
Hi I need Help to remove password on HP EliteBook 645 G9, S/N 5CD243HVQQ. I have uploaded both ec and main bios.
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
I noticed there's a lot of unlock request for this model HP EliteBook 645/655 14/15.6 inch G9
The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you shouldFlash Both.
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU and put your original DMI
This bios is extracted from hp website so its fast boot this would work in two models 14 and 15 inch they have the same bios.
To determine your BID use any hex editor and search for the BID. Ex: U77
frequently asked questions:
can i use this to my HP EliteBook 645/655 14/15.6 inch G9- yes
This is the both BID U77 and U87 its all you need.​Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you Rex I hope it will help a lot of other guysI noticed there's a lot of unlock request for this model HP EliteBook 645/655 14/15.6 inch G9
This is the both BID U77 and U87 its all you need.Comment
Please unlock mine got administrator password
HP EliteBook 645 G9
SN# 5CD2471XBC
ProdID 6J5H9AV
HP EliteBook 645 g9 unlock
5CD3085B3YAttached Filesif you find these attachements useful please consider making a small donation to the site
Please i need help, i got HP EliteBook 645 G9 AMD Ryzen. its not intel processor
Product ID: 766R9UC#ACQ
Serial number: 5CD243HVQS
Motherboard: DA0X9SMB8D1 REV: D MODEL: X9S
I NEED MAIN BIOS BIN & EC.
I have made a backup file. i have tried some bin files posted here but nothing works what i have noticed is that most files are for intel processor. i also download bios update from HP site but i am failing to extract the bin files can someone help pliz. With original file the fan spins and processors warms normal but black screen. when i try some bin files posted here some only blink caps lock only 5 times but it does turn on or spin fan.
Try these , don`t know if you have U77 or U87 so try both .Flash main and EC_bios for each one. https://www.badcaps.net/forum/troubl...96#post3683596
HP EliteBook 645 G9
SN 5CD3172XW5Attached Filesif you find these attachements useful please consider making a small donation to the site
This device is AMD, not Intel, and most of the bios found here are for Intel.Comment
Thank you rex98​I noticed there's a lot of unlock request for this model HP EliteBook 645/655 14/15.6 inch G9
Dear Experts,
Is it possible to unlock my BIOS? I have tried every script individually, but the password remains.
In attachment the dump.
Thanks a lot and have a nice evening
Alex
Every donation made will go towards server fees and maintenance costs.Comment
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
Dear Sir,
I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
Problem details:
* Service Tag: (HMHJQ93)
What I need:
Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
In the attachment...-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
