can someone modify my bios and disable the buit in RAM if possible in bios modifying. if not possible please give me pictures or guide how to disable via motherboard method.
Lenovo V310-14Ikb DA0LV6MB6F0 rev f bios mod
Re: Lenovo V310-14Ikb DA0LV6MB6F0 rev f bios mod
try this..Attached Filesif you find these attachements useful please consider making a small donation to the site
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
