Tulpar T5 V18.1 bios dump
  • yucel-yucel
    • Dec 2017
    • 148
    • türkey
    Monster Tulpar T5 V18.1 south chip has been replaced. After replacing the SR40B, the bios needs to be cleared. If anyone has a working bios or can help me clear my bios, thank you in advance.
    motherboard code gk5cn6x v1.1
    • 22279
    Re: Tulpar T5 V18.1 bios dump
    You have 6 other threads where youve changed the chipset and needed the ME cleaning. It will be a good idea to try and learn how to clean the ME firmware yourself,there are lots of guides on youtube,and we have asome guides as well https://www.badcaps.net/forum/showpo...41&postcount=3
    • yucel-yucel
      • Dec 2017
      • 148
      • türkey
      Thank you
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
