DAG3PMB18B0 bios
tested and working bios.
when there is no image you must check hardwareAttached FilesComment
you write it with errors... remove the bios chip from the board before writing or reading... solder it to the programmer or put it in the adapter and then in the programmer... don't use the clip, it gives errors... if you don't have anything to solder it with, solder wires between the chip and the programmer..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I desoldered the chip, placed it in the EZP 2023 programmer, flashed it, and then soldered it in place!
you write it with errors... remove the bios chip from the board before writing or reading... solder it to the programmer or put it in the adapter and then in the programmer... don't use the clip, it gives errors... if you don't have anything to solder it with, solder wires between the chip and the programmer..Comment
SIR
NEED BIOS FOR HP VICTUS
OLD BIOS ATTAHED
MODEL: 15-FA0353TX
SN: 5CD320B138Attached FilesComment
bios extracted from HP website update for Victus Gaming Laptop 15-fa0353TX (6N030PA)
DMI 801000 -80300F
KEYWIN 8A6000 - 8A603FAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
 - External display (HDMI) shows
							Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
			by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
			by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
 - Loading...
