Need help repair bios for UX482EAR. I tried backup twice but nothing on the chip, then i found this bios that can turn on the laptop. But i think different model cause from this file for UX482EA and my board UX482EAR. ALready tried build it but no success. Thanks before
Re: help repair bios for UX482EAR
Got it & tested. Here for other who need itAttached Filesif you find these attachements useful please consider making a small donation to the site
hi,
Any one please help to repair my laptop
led power on when charger plugin
I haven’t ori file
MAINBOARD : UX482EGR R3.0
SN : MSNOCV12P60537D
Thanks2 PhotosComment
https://www.badcaps.net/donateComment
Thank you for your fast reply
I bought the Pc without a bios chip, I loaded a version from the attached web
the correct Serial is
SN : M9N0CV12P60537D
see attachementAttached Filesif you find these attachements useful please consider making a small donation to the site
You already have the bios file, what else do you need ?↵
Is this the right file? because I still have the same problem, power light (keyboard) on fixed and both lights in the card fixed, no power and no displayComment
Try this file, if it doesn't work then unfortunately the problem is not bios.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you for your help, indeed I must have another problem because all the bios I tested returns to the same symptom.
Frustrating because all voltage is present on the coils,
I uploaded the programming of the IT8125VG-128 chip
maybe you could take a lookAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
