help repair bios for UX482EAR
  • Bonzas
    • 472
    • Indonesia
    Need help repair bios for UX482EAR. I tried backup twice but nothing on the chip, then i found this bios that can turn on the laptop. But i think different model cause from this file for UX482EA and my board UX482EAR. ALready tried build it but no success. Thanks before
  • Bonzas
    • 472
    • Indonesia
    Re: help repair bios for UX482EAR
    Got it & tested. Here for other who need it
    • Vincent974
      • Sep 2021
      • 5
      • Réunion
      hi,
      Any one please help to repair my laptop
      led power on when charger plugin
      I haven’t ori file
      MAINBOARD : UX482EGR R3.0
      SN : MSNOCV12P60537D
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        Originally posted by Vincent974
        hi,
        I haven’t ori file
        Backup origin bios file even if it's broken.
        • Vincent974
          • Sep 2021
          • 5
          • Réunion
          Thank you for your fast reply
          I bought the Pc without a bios chip, I loaded a version from the attached web
          the correct Serial is
          SN : M9N0CV12P60537D
          see attachement​
          • hoaca388
            Badcaps
            • Jan 2022
            • 12268
            You already have the bios file, what else do you need ?
            • Vincent974
              • Sep 2021
              • 5
              • Réunion
              Is this the right file? because I still have the same problem, power light (keyboard) on fixed and both lights in the card fixed, no power and no display
              • hoaca388
                Badcaps
                • Jan 2022
                • 12268
                Try this file, if it doesn't work then unfortunately the problem is not bios.
                • Vincent974
                  • Sep 2021
                  • 5
                  • Réunion
                  Thank you for your help, indeed I must have another problem because all the bios I tested returns to the same symptom.
                  Frustrating because all voltage is present on the coils,
                  I uploaded the programming of the IT8125VG-128 chip
                  maybe you could take a look
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    Hi everyone
                    09-06-2025, 05:47 PM
                  • Forest79
                    by Forest79
                    07-23-2023, 07:39 AM
                  • maanee11
                    Help to get Lenovo BIOS bin file for Thinkpad T560
                    by maanee11
                    Hello Everyone,
                    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                    05-15-2022, 11:59 AM
                  • Sebastian Codrean
                    BIOS file for ASUS F542UN laptop
                    by Sebastian Codrean
                    Hello to all of you! I need help with a BIOS file.
                    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                    02-20-2025, 10:25 AM
