Alienware M15 Ryzen Edition R5 bios
  • aussietony
    • Aug 2018
    • 4
    • France
    New member here, long time watcher, I have a Alienware,Service Tag 64S3RF3 M15 R5,
    After a windows updade it rebooted with no video on HDMI or screen,
    Could someone who had copied the bios.bin file and uploaded it here please help me identify exactly which chip is the main bios.
    Thanks very much Tony
    • volinakis
      • Jan 2021
      • 2873
      • N/A
      UC7
      • aussietony
        • Aug 2018
        • 4
        • France
        Thanks very much.
        • aussietony
          • Aug 2018
          • 4
          • France
          Hi, I removed the bois chip and tried to reprogram it, however I think I need the Service Tag in the file, I tried to insert the Tag but i'm having problems.
          The board is a LA-k453p Rev 1.0
          its a Ryzen CPU.
          Model number P109F -M15 R5
          Service tag - 64S3RF3
          would someone be kind enough to embed my service tag into
          a bios.bin
          • volinakis
            • Jan 2021
            • 2873
            • N/A
            its a Ryzen CPU.
            a bios.bin
            post bios backup and bios file you wrote into bios chipset.
            • aussietony
              • Aug 2018
              • 4
              • France
              #26
              The backup i made did not seem to copy correctly, I think because i was not using the reader correctly.
              Attached is a be bin file i downloaded from here, one of your's where i used a hex editor to find and replace the service tag number.
              thanks for your assistance,
              • sorehammer
                • Jun 2025
                As the title says my power button has a issue, it only shows blue I've contacted Dell which led no where the service tag is 2YPR0H3 If ny one has a way to update it's firmware/bios I would appreciate it.
                  SMDFlea commented
                  Editing a comment
                  Thread merged..next time please look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12278
                #28
                You MUST:
                • Read BIOS guides, methods, resources and tools
                • Try the method at BIOS guides, methods, resources and tools before requesting help
                • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                • Use search function in case someone already answered your request
                • Post under a related thread if it exists
                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                • Name your thread with make, full model numbers and request
                • Provide a BIOS/EC dump if possible
                • Attach files directly to your post instead of linking to external websites
                • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                • BOGOSY77
                  • Aug 2018
                  • 52
                  • PITON
                  #29
                  Originally posted by volinakis
                  try
                  THANK YOU FOR THIS BIOS, YOUR BIOS WORKS WELL. YOU ARE A MASTER ON THIS. THANKS,
                  • nissimezra
                    AMMTS-SH Alienware Aurora Ryzen Edition R10 Bios dump
                    by nissimezra
                    Device: DESKTOP PC
                    Brand: DELL
                    Model: Alienware Aurora Ryzen Edition R10
                    Service Tag: 3WVDTH3
                    Express Service Code: 8517977463
                    Board number: AMMTS-SH REV A00
                    Request: BIOS dump
                    Problem,: Black screen
                    CPU Ryzen 7 5800
                    No error code just black screen
                    thank you...
                    05-19-2025, 10:52 AM
                  • DavidChunco
                    Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                    by DavidChunco
                    Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                    - Receive help from Dell Support (it is out of warranty).
                    - Disconnect machine from AC power and battery overnight.
                    - BIOS recovery process
                    - Connected external display via HDMI
                    - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                    03-15-2025, 11:00 AM
                  • drux
                    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                    by drux
                    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                    These models have AMI/Aptio BIOS.
                    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                    11-03-2024, 01:18 AM
                  • Arc717
                    How do I flash bios to an Alienware M16 R1 AMD edition?
                    by Arc717
                    I am trying to downgrade my bios on my Alienware so I can undervolt & overclock my CPU, and overclock my ram. I need to get to bios 1.2.2 for this. Dell doesn't allow downgrades, and their bios file is an exe compiled in c++, so I can't decompile it easily. I am wondering if I can flash the bios manually using a usb flasher. I would like to know if this is possible, and if so, where the bios chip would be. I know flashers are pretty cheap and the bios chip is 8-pin. There are two of these chips only when I open the back panel of the laptop. I'm not sure if there are any on the other side of...
                    05-17-2024, 03:34 PM
                  • Jclark87
                    Alienware M15 R5 Ryzen Edition GDL56 LA-K453P boardview & schematic
                    by Jclark87
                    Hey guys I have a buddy that spilled liquid on his Alienware and now when powered on it says it cannot detect the hard drive. I'm sure the circut is shorted I'd like to replace all the components in that circut and get the board all cleaned up.
                    Its a Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0
                    I really need the board view.. i think i have the correct scematics but if you could also post those so im 100% sure i have the correct ones that would be great!
                    But board view for sure please and thank you 😊
                    08-24-2025, 11:47 AM
