Tiny Hexer macro scripts
  • shamzeli
    • Aug 2024
    • Turkey
    Originally posted by SMDFlea
    A script to disable ram in the bios. An alternative to the SPD ram removal tool,which is reported to have viruses.
    This works ok for DDR4,works ok for some lenovo models,it could work with others,don`t know.It does exactly the same edits as
    SPD removal tool.Tested on 12 different bios.
    Edit: By default SPD removal tool pre-selects all of the SPD RAM sections for patching.This MPS script also patches all sections. If you
    want to remove sections seperately use a hex editor.
    1. Install Tiny Hexer,you`ll find a link to it in post 1 .
    2. Make a new folder on your C: drive called "DISABLE RAM" without the quotes ""
    3. Move or copy the bios and the "Disable RAM.mps" script to the folder
    4. Rename the bios to disableram.bin
    5. Run the script,a box should pop up saying how many replacements were made, click ok,close Tiny Hexer and save when asked.
    Give if it has worked for you
    Thank you very much.
    • bushmann
      • Feb 2014
      • 147
      • Slovakia
      Generic CopyDMI Scripts to complement the Experienced Copy DMI guide:
      Copy DMI info easily with Hex editing software and Macro script
      https://www.badcaps.net/forum/showthread.php?p=1214739
      Tiny Hexer - https://www.softpedia.com/get/Others...ny-hexer.shtml
      Post your generic scripts in this thread, no bios requests or any other questions , just scripts that everyone can use for any bios with the same *DMI off-sets. Posting a thank you is ok though,if you find what everyone posts useful.
      The scripts can be named anything you want but the bios naming must be the same as they are in the guide when you make the scripts otherwise they won`t work.
      *DMI. The scripts don`t have to be just for DMI,they can be used for anything that uses the same fixed offsets.
      It also works on ASUS FX502VD.​
      • Micki90
        • Nov 2016
        • Argentina
        Originally posted by mauri1990
        Thank you, worked perfectly on Lenovo V330 15ikb
        Can you share de .bin? Thanks
          • 21960
          You should patch your own bios, that way you will keep the serial number etc. If you don`t have a backup or want help with your own bios post your request in this thread -> https://www.badcaps.net/forum/troubl...ios-v330-15ikb
          • Satyam Ganju
            • May 2025
            • India
            How do I flash this newly created file after running the script ?.
              SMDFlea commented
              Editing a comment
              With an SPI programmer. Make a backup of your original bios first.
          • Morthyr
            • Jul 2014
            • Poland
            #26
            Works with ASUS X515JA MB: X415JA R2.2
            • AlbertoZ
              • Mar 2024
              • 5
              • Italia
              #27
              Works with Asus 9461NGW P1510JCA and Acer Extensa 15 N19C1. I resumed both.
              Thanks​
              • tomodachi
                • Apr 2012
                • 612
                • Turkey
                #28
                Thank you very much SMDFlea
                it worked perfectly on NM-D471 (Lenovo Ideapad 3 15ITL6 )
                • mnblck1
                  • Sep 2017
                  • 7
                  • Indonesia
                  #29
                  Work on Lenovo NM-D474
                  Thank you
                    by SMDFlea
                    Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                    Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                    02-28-2023, 02:14 PM
                    HP factory bios patcher
                    by SMDFlea
                    * DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                    * The unlock scripts given here are for personal use only, ie. you accidentally set a password on your own
                    * machine,you forgot the password you set a long time ago or you mistyped the password when setting it
                    * and cannot get in again.
                    10-20-2024, 12:52 PM
                  • chth96
                    Is it possible bridging tiny broken trace
                    by chth96
                    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                    cutting tiny trace.
                    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                    12-03-2022, 11:32 PM
                    LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
                    This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-12-2024, 03:36 PM
