Problem with Nitro AN517-41
  • nick_rusev
    • Aug 2016
    • 10
    There is a problem with the laptop. The laptop was working just fine. When I replaced the original display(BOE NE173QHM-NY6 V8.0) with a new one(BOE NE173QHM-NY2 V8.0), it started making problems. It tried to start - the keyboard lighted from left to right and tried to turn on but the display was just black. I waited for 10-15 seconds and I turned it off from the power button. Then I replaced the display back again to the original one and tried turning it on but it just lights the keyboard up and immediately shuts down. Could the problem be because I didn't wait long enough for the BIOS to update and the DMI part of the BIOS got damaged? And if this is the case, is it restorable and how could i fix it? Thanks in advance!
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    • Gadget & motorcycle addicted
    Re: Problem with Nitro AN517-41
    Originally posted by nick_rusev
    There is a problem...
    Most probably you didn't disconnect the battery before playing with the screen (connector), did you?
    Become a Badcaps supporter
    Thanks to all supporters.
    • nick_rusev
      • Aug 2016
      • 10
      I did remove it before changing the display.
      • nick_rusev
        • Aug 2016
        • 10
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Good for you, otherwise all kind of problems can happens.
          In general, since the laptop was working properly before, changing the display alone should not cause any problems, especially since even the model and characteristics of the new and old screens are almost the same. And since the battery has been also disconnected as it should be at this procedure, there is no reasonable explanation of what is happening.
          • mgourgios
            • Nov 2018
            • 47
            • Greece
            Hello.
            I need to repair this laptop which was bricked by the customer with custom mod bios or something and has no backup of course.
            The laptop powers on without image.
            Laptop Info:
            ACER NITRO 5 AN517 N20C2 (AN517-41-R9S5)
            Mobo: GH53Z LA-L031P
            S/N: NHQBHEV00311218EAD3400
            Thank you.
            • peste
              peste commented
              Editing a comment
              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • EasyPeasyMK
            • Dec 2025
            I’m looking for a working 16MB SPI BIOS dump for the following laptop:
            Model: Acer Nitro 5 AN517-41
            Board / Model No: N20C2
            CPU: AMD Ryzen 7, 5000 Series (Cezanne)
            BIOS chip: Winbond W25Q128JVSQ (1.8V, 16MB)
            Programmer: CH341A (with 1.8V adapter) Problem:
            The laptop has no display output (black screen).
            Fans spin, power LED is on, but no image on internal or external display. What I already tried:
            • Read and backed up the original BIOS (16MB dump available)
            • Acer BIOS update package contains an 18MB abobios.bin, not SPI-flashable
            • UEFITool reports “UEFI volume not found” (common for this AMD Acer model)
            • BIOS was flashed externally, but system still shows no image
            What I need:
            • A known-good 16MB SPI BIOS dump for AN517-41 / N20C2
            • Same board revision / Ryzen 5000 platform
            • Dump must be exactly 16,777,216 bytes
            If someone has:
            • a tested dump
            • or can share a clean/full SPI image
            • or is willing to help reconstruct a working BIOS
            I can provide my original backup dump if needed.
            I would really appreciate your help.
            Thank you in advance!
            • peste
              peste commented
              Editing a comment
          • peste
            • 15041
            • ROMANIA
            post S/N,,etc.
            post the contents of the bios chip even if it is corrupted..
            If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
            It only takes 1 minute:
            https://www.badcaps.net/settings/subscriptions
            • EasyPeasyMK
              • Dec 2025
              SN: NHQBHEG00213209FD53400
              I can't upload the .bin
              • peste
                • 15041
                • ROMANIA
                archive it with winrar or 7 zip
                • EasyPeasyMK
                  • Dec 2025
                  Okay thanks, this is my Backup from Bios
                  • konovalec85
                    • Sep 2018
                    • 15
                    • Украина
                    Acer Nitro AN517-41-R2HB
                    Model:N20C2
                    S/N: NHQBHEV00V14117D153400
                    GA53Z LA-L031P REV 1B
                    The laptop turns on, but there is no initialization, the keyboard backlight works, there is no image.
                    I found a dump on Google. Well, the size is too big. 16385kb My file size is 16384
                    Maybe someone can help with another working bios dump
                    • Stf69 Lucky
                      • Jan 2025
                      Hello and happy new year , i Need help with an Acer nitro5 .
                      I writed a new bios but i have no Image , laptop start normal i hear the Windows Sound ist stable but no Image and HDMI no Image to
                      how can it be posible ? Something Wrong with bios i think
                      can someone Make a clean bios for this model ?
                      An517-41-r2u9. Its an ryzen7 5gen with and rtx 3080
                        • 23614
                        Post the laptop serial number, original bios backup and motherboard model number .Please familiarise yourself with the forum rules - https://www.badcaps.net/forum/troubl...before-posting
                        • huzo
                          • Sep 2014
                          • 200
                          • CROATIA
                          • electronics mostly,gaming, keyboadr and accordeon player
                          Guys,did someone manage to solve this problem? I have the same issue! The screen was broken , i got the new one, and from that moment on the board does not POST! Caps lock doesn't work,no image, HDMI dead too.. What could cause the board to die after replacing the screen?? Ofcourse i disconnected the battery and PSU...I tried a dump found here,but maybe i need to upload my original to have it repaired? But why would bios image die after replacing the screen?
                          I have only keyboard light...
                          • peste
                            • 15041
                            • ROMANIA
                            Have you tried turning on the laptop again, without the display...or with the original display...does it turn on???
                            • huzo
                              • Sep 2014
                              • 200
                              • CROATIA
                              Yeah ofcourse, without the display, with old display,not working...Fans spin, cpu,gpu gets hot,keyboard lights are on, but no post..I don't get the +LCDVDD, INWPWRB+ is present...What else could lock the board unusable? Is there some protection as on apple devices? Can i post here the dump , maybe you can check it? I noticed there is a smaller bios chip , That's probably the GPU bios? i am not at home to check on the schematics...What could cause the board to have no picture? Is there a lock of some sort?
                                • 23614
                                The bios shouldn`t die just by replacing the screen. Is the replacement the same part number or a different model
                                • huzo
                                  • Sep 2014
                                  • 200
                                  • CROATIA
                                  different model,but 40 pin as the original...shouldn't have any influence...
                                  • Boardview and Schematic Bot
                                    ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                    This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                    09-12-2024, 03:28 PM
                                    ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                    This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  • fmajbour
                                    Acer Nitro 5 model A515-51 keyboard problem
                                    by fmajbour
                                    I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                    Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                    i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                    I have check the keyboard connector on the mainboard every thing looks ok.
                                    Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                    I need your advice if anyone face...
                                    11-13-2023, 09:50 PM
                                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 04:10 AM
                                    Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
