DELL e5440 mec5075-lzy kbc firmware
  • Fencus
    • Oct 2022
    • 16
    • Hungary
    Hello guys.
    The old one was shorted so i had to change it I cannot read the old file. I need a file for FOR THE MEC5075(U38), bios(U1,25q64) and ec(U2,25q32) not needed, I already have them. Thanks for help.
  • cahaya rezeki rizki
    • Mar 2024
    • Indonesia
    Hllo are you found file MEC5075? I need, please share to me if you found
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
  • hazem3636
    need Bios Bin file Dell server 220
    by hazem3636
    hi everyone
    i need dump file for dell server r220
    i have download Flash BIOS executable file but i dont know how to conver it to Bin file
    i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
    if anyone has this method please need his supporting .
    all the best
    EXE file is attched and Original Bin file from the Bios Chip is attached also
    and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
    11-05-2022, 06:20 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Daniel Larsson
    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
    by Daniel Larsson
    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
    During these seconds the function button is not working...
    08-13-2025, 10:29 AM
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
