DELL e5440 mec5075-lzy kbc firmware
  • Fencus
    • Oct 2022
    • 10
    • Hungary
    Hello guys.
    The old one was shorted so i had to change it I cannot read the old file. I need a file for FOR THE MEC5075(U38), bios(U1,25q64) and ec(U2,25q32) not needed, I already have them. Thanks for help.
  • cahaya rezeki rizki
    • Mar 2024
    • Indonesia
    Hllo are you found file MEC5075? I need, please share to me if you found
  • hazem3636
    need Bios Bin file Dell server 220
    by hazem3636
    hi everyone
    i need dump file for dell server r220
    i have download Flash BIOS executable file but i dont know how to conver it to Bin file
    i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
    if anyone has this method please need his supporting .
    all the best
    EXE file is attched and Original Bin file from the Bios Chip is attached also
    and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
    11-05-2022, 06:20 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    EDIT: Rev 65...
    01-26-2025, 06:22 AM
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
  • GeckoGreen
    Samsung service bulletin: need firmware file for PN63C550 TV
    by GeckoGreen
    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
    Will you please help me get the [2D63]LOGIC.bin file for my TV?
    05-17-2025, 02:47 PM
