HP 840 G6 Endpoint Security Controller reported on Boot Screen
hello
smdflea
i try the patcher white no luck
So i ask you guys
Regards chrisLeave a comment:
You still have an extra 1KB in your file, did you read this -> Your bios is 32,769KB and should be 32,768KB ,i suspect the extra code has been added because you chose an OTP chip, you should choose a non OTP chip then it won`t add any extra .
And did you try what peste linked to, the script patcher will patch it for you, if you follow the instructions.
https://www.badcaps.net/forum/troubl...26#post3589426 -
hello
i send the wrong file about the endpoint problem
sorry for that
here is the good file
5CG0338SS1Attached FilesLeave a comment:
Step 1. Flash EC + This Patch file. Then Boot blank or black display will appear.
Step 2. Flash Only Your Main Dump File.
Hope that will solve the endpoint error.Attached FilesLeave a comment:
Hello
I also need help whit endpoint error
serial 5CG0338SS1
840 g6Attached FilesLeave a comment:
HP Elitebook 840 G6 (EndPoint Security Controller Problem)
6050a2945601-mb-a01
SN: 5CG9510R33Attached FilesLeave a comment:
endpoint security controller problemAttached FilesLeave a comment:
Try this patcher -> https://www.badcaps.net/forum/troubl...security-error -
hello please help
please help with endpoint security controller problem on boot
hp elitebook 840 g6
ProdID 9JW45UC#UUF
sn# 5CG01GP73Leave a comment:
by Junior††not sure how it happened but after replacing the screen on a2251 macbook it:
fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
thermal camera shows these are getting quite hot although i'm not sure what do to.
i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...07-15-2025, 09:17 PM -
by kolebbkHi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
HP Endpoint Security Controller problem
there is a problem with the hp endpoint security controller on the unit
I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...-
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by fede77Notebook HP ProBook 450 G8
ProdID 2K8L1LT#AC8
Mother: DAX8QAMB8D0 REV D
The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....03-10-2025, 07:12 AM - Loading...
