Originally posted by Lovro25
View Post
HP 840 G6 Endpoint Security Controller reported on Boot Screen
Hello, I have the same problem can someone please help
HP EliteBook 840 G6
SN: 5CG9463MW5Attached Files
Originally posted by arif3203 View PostHalo I have a Laptop that has a Endpoint Security Controller Problem.
Can it be removed?
HP 840 G6
SN: 5CG0278SL8Attached Files
Can it be removed?
HP 840 G6
SN: 5CG0278SL8
Can it be removed?
HP 840 G6
SN: 5CG0278SL8
Originally posted by rickjansen01 View PostHello smdflea
here the ec file for the endpoint error
5CG0338SS1Attached Files
Hello smdflea
Originally posted by Bios Cracker View Post
Try this file....
Step 1. Flash EC + This Patch file. Then Boot blank or black display will appear.
Step 2. Flash Only Your Main Dump File.
Hope that will solve the endpoint error.
hello
smdflea
i try the patcher white no luck
So i ask you guys
Regards chris
You still have an extra 1KB in your file, did you read this -> Your bios is 32,769KB and should be 32,768KB ,i suspect the extra code has been added because you chose an OTP chip, you should choose a non OTP chip then it won`t add any extra .
And did you try what peste linked to, the script patcher will patch it for you, if you follow the instructions.
https://www.badcaps.net/forum/troubl...26#post3589426
hello
i send the wrong file about the endpoint problem
sorry for that
here is the good file
I also need help whit endpoint error
serial 5CG0338SS1
840 g6
Hope that will solve the endpoint error.Attached Files
serial 5CG0338SS1
840 g6
https://www.badcaps.net/forum/troubl...security-error
Hello
serial 5CG0338SS1
840 g6Attached Files
