Hp 14-dq1077wm bios dump
  • max_sneka2
    • Mar 2022
    • 81
    • iraq
    Hello every one
    i need bios dump for hp 14-dq1077wm
    board number da0padmb8g0 rev g
    here is old dump
  • peste
    • 13430
    • ROMANIA
    Re: Hp 14-dq1077wm bios dump
    Originally posted by max_sneka2
    Hello every one
    here is old dump
    use the bios from post #5.. the DMI and Keywin information post #3.....
    https://www.badcaps.net/forum/showth...ighlight=086C8
    • hardware1
      • Sep 2021
      • 2946
      • N/A
      Hello every one
      here is old dump
      Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
      Serial Number: 5CD042TZ2J.
      all donations are welcome,
      • max_sneka2
        • Mar 2022
        • 81
        • iraq
        testing now
        • max_sneka2
          • Mar 2022
          • 81
          • iraq
          its working fine ... thank you
          • kameldw
            • Mar 2023
            • 10
            • algerie
            thank you
            • hardware1
              • Sep 2021
              • 2946
              • N/A
              Good to know, You're Welcome.
              • flo70
                • Dec 2022
                • 22
                • france
                hp 14s-dq1009nf
                Hi all
                help me find a clean bios for this model please
                thanks all
                DA0PADMB8F1 REV : F
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Re: hp 14s-dq1009nf
                  Originally posted by flo70
                  Hi all
                  thanks all
                  DA0PADMB8F1 REV : F
                  Here you are (DMI and Windows Key added):
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • flo70
                    • Dec 2022
                    • 22
                    • france
                    Thank you very much
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Thank you very much
                      You're welcome.
                      Please consider donation in support of the "Bios Requests" section of the forum.
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        by haitham sharabati
                        Hello engineers 😀,
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        💀 Problem:😅
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
