Please help me unlock this HP 830 g9, i attach both 256 files, thanks in advance!
Help unlock HP EliteBook 830 G9
Tags: None
Re: Help unlock HP 830 g9
Can anyone please help me? I can't do it with RCUnlocker since there are two 32mb files -
In the first boot go to bios menu and disable security options (Default).Attached FilesComment
Still asks for password.... Power on, manufacturing mode, booted into bios, went to security, checked default factory settings and asked me for administrator password.Comment
Correction, restareted, but first loaded bios factory defaults, save and exit and then at the next boot reseted security settings and it worked. Thank you very much for the help!Comment
One more problem, i added all the system ID to exit manufacturing mode, but now i have an error
MPM
Product Information not valid. The following product information programmed into the system board is missing or invalid
Cirrus Discrete Amp Calibration Data
Press space bar to continue or "Y" to enter missing infoComment
MPM
https://www.youtube.com/watch?v=9T57ktw8n3YComment
MPM
Serial Number: 5CG2433C0T
SKU : 5P6W8EA#UUW
BuildID : 22WWWPAT602#SUUW#DUUW
Feature Byte : 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfAfPfXguhKhkj4jhk8mEmVmwn7nVngpTpWpqq
System Board CT Number : PPLRT00WBHA01LComment
Yes i already entered all the info that is necessary! From the sticker on the cover, but it asks me that Cirrus calibration thing. Cirrus seems to me like audio. As for the the touchpad and other peripherals, all work ok.Comment
MPM
Can anyone help me with this error?Comment
https://wise.hp.com/wise-services/co...s/EN/c08358400
Please refer to the corresponding pdf document.
Only available in unlock mode.Comment
HP Commercial Notebooks and Mobile Workstation PCs - Error Message 'Cirrus Discrete AMP Calibration Data
Missing' Appears During Branding Process
1. d5273_amp_calibration_tool_sop.pdf- A PDF file that contains the SOP instructions to perform the repair.
2. Amp Calibration tool by Family.7z - 7z zip file that contains the calibration tool for impacted computers.
NOTES: Click the paper-clip icon in the left bar to reveal the attachments. Right-click on the attachment to
download it. You may not be able to see or access the attachment. In that case, save this document, and open it
with Adobe Reader.
If you have opened it in a Web browser, you may not be able to see or access the attachment. In that case, save
this document, and open it with Adobe Reader.
References: SIK4152 , SID5273Comment
Can you please attach the files here. Thank you
with Adobe Reader.
you can try this file.if everything ok reply for me.Attached FilesComment
Ah yes, this that stupid Audio Calibration data thing on some newer models. You can't edit it via the BIOS menus like the feature byte etc, only that UEFI proprietary tool that HP uses internally where you can calibrate it.
But alternatively you can edit more CMOS string values manually using a USB EFI shell with the "UefiBiosConfig.efi" tool.
If it's similar to va "HP EliteBook 860 16 inch G9 Notebook PC" you can try my personal dumped calibration data for the audio chip. (Hope it doesn't screw it up)
Anyway make a bootable USB EFI Shell, extract the zip into the root of the USB. Navigate to EFI\Boot and copy my dumped cirruscalibrate.txt into there.
Then boot into your USB EFI Shell (might need to turn off secure boot).
Make sure you navigate to the USB drive then go to EFI\Boot
Code:UefiBiosConfig -getconfig=cirruscalibrate.txt
Code:UefiBiosConfig -getconfig=cmosdump.txt
Code:UefiBiosConfig -setconfig=cmosdump.txt
If you get a red screen of death on reboot about some stupid programming mode, run this:
Code:UefiBiosConfig -setconfig=lockmpm.txt
Code:UefiBiosConfig -setconfig=cirruscalibrate.txt
Couldn't edit the post a 2nd time hahaLast edited by SMDFlea; 09-21-2023, 01:10 AM.Comment
This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:50 AM
HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or RepairThis specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 05:20 AM
This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:20 AM
- Loading...
