Good day. Please help me figure this out. I can't defeat this notebook. I've tried a million different combinations. If I understand correctly. I need to break the main BIOS so that the EC is rewritten at the moment of the first turn on. I delete almost all information. It doesn't require a password when logging in. But I can't reset the security settings to factory defaults. Maybe I can somehow delete them from the EC flash drive? Please help me with advice.
Help unlock HP EliteBook 830 G9
here thank you for your patience.
first boot press f10 apply factory defaults and exit.
use BCU
here's your DMI:
Serial Number: 5CG3026WZX
Product #/SKU: 479Z1AV
CT Number: PMYET00WBHL043
Description: HP Elite x360 830 13 inch G9
BuildID: 22WWWPBZ601#SABD#DABD
Feature Byte: 476J6S6b7B7H7M7R7W7maBaEapaqauawbVcAd6eMfPfXguhKhkj4jhk8mEmVn7nVngpDpVpWpnpqprqjqz.7f
MAC Address : 7C:4D:8F:36:C9:66Attached FilesComment
use BCU
here's your DMI:
MAC Address : 7C:4D:8F:36:C9:66At the first boot it gives this message. Is it maybe because of different versions of BIOS and EC firmware? How to fix it?
Hello to all masters. Help. I can't solve the problem with Intel Smart Sound Technology OED. I flashed the original BIOS back. It doesn't help. I was able to remove the password only by flashing someone else's unlocked BIOS. Then I returned mine back. Maybe someone has encountered and solved this problem. Please advise.Comment
I have a suspicion that someone has already tried to unlock the laptop. I did not immediately check whether this error was there before all the manipulations. I am attaching the BIOS and EC firmware. Maybe someone who knows will see what is wrong?Attached FilesComment
Re: Help unlock HP 830 g9
Ah yes, this that stupid Audio Calibration data thing on some newer models. You can't edit it via the BIOS menus like the feature byte etc, only that UEFI proprietary tool that HP uses internally where you can calibrate it.
But alternatively you can edit more CMOS string values manually using a USB EFI shell with the "UefiBiosConfig.efi" tool.
If it's similar to va "HP EliteBook 860 16 inch G9 Notebook PC" you can try my personal dumped calibration data for the audio chip. (Hope it doesn't screw it up)
Anyway make a bootable USB EFI Shell, extract the zip into the root of the USB. Navigate to EFI\Boot and copy my dumped cirruscalibrate.txt into there.
Then boot into your USB EFI Shell (might need to turn off secure boot).
Make sure you navigate to the USB drive then go to EFI\Boot
Code:UefiBiosConfig -getconfig=cirruscalibrate.txt
Code:UefiBiosConfig -getconfig=cmosdump.txt
Code:UefiBiosConfig -setconfig=cmosdump.txt
If you get a red screen of death on reboot about some stupid programming mode, run this:
Code:UefiBiosConfig -setconfig=lockmpm.txt
Whoops I meant
Code:UefiBiosConfig -setconfig=cirruscalibrate.txt
Couldn't edit the post a 2nd time haha) After entering all the data for the BIOS, waited for the count down to get to 1 and accept my information but SURPRIZE
) "Cirrus discrete bla bla error" and was stuck like that for more than two days
( But than i've found this post and everything WORKED GREAT !!! Only one thing, deactivating Secure Boot it's a MUST not a Might. If you can update the zip file with Bootx64.efi would be great for beginners like me would be the BEST. Anyway, whoever get the error about Cirrus Discrete, should use with 100% confidence Kippy's solution . And if anyone know someone from HP that worked on the G9 models and up, please fell free to kick them in the nuts
) I mean, what the hell with all this sh*t??? Up to G8 models this didn't happen !! Once again, KippyKip, a million thanx to you! Take care and keep helping poor fellas !
Can you please unlock my BIOS please?
Serial: 5CG24211LW
SKU Number: 757Y2EC#ABU
Every donation made will go towards server fees and maintenance costs.Comment
Serial Number: 5CG24211LW
Product #/SKU: 757Y2EC#ABU
CT Number: PPLSA00WBH8723
Description: HP EliteBook 830 13 inch G9 Notebook PC
BuildID: 22WWWPAT602#SABU#DABU
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAdpdq eMfPgSguhKjhk8mEmVmwn7nVngpDpFpVpqqjqz.aBComment
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAdpdq eMfPgSguhKjhk8mEmVmwn7nVngpDpFpVpqqjqz.aBAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you very much.Comment
Hi can someone please help me unlock my laptop bios.
Product Name: HP EliteBook 830 13 inch G9 Notebook PC
Product Number: 4B5S7AV
Software Build Number: 22WWWPBZ601#SABA#DABA
Serial Number: 5CG25121HV
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEn7nVngpDpFpVpnpqprqjqz.Hq
Hello freind i have HP Elite x360 830 G9 2-in-1
i need à clean bios backup me region
the laptop hase bios password someone try to unlock it but not with the original backup Hé corrupte the original EC+MAIN BIOS
NOW LAPTOP IS WORKING BUT LATE DISPLAY AFTER 1 OR 2 MIN
PLEASE SOMEONE SEND ME A CLEAN ME BIOS THANK YOUComment
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
SN: 5CG3361NFD
prodID : 6W5Y3UC#ABA
HP ELITE X360 830 G9 2-IN-1
laptop work without original bios but probleme is late display i need new bios with clean csme region
THIS BACKUP NOT ORIGINALAttached FilesComment
use BCU
here's your DMI:
what is the version of flash image tool to read bios of 830 G9 2-in-1
This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:50 AM
HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or RepairThis specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 05:20 AM
This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:20 AM
- Loading...
