Help unlock HP EliteBook 830 G9
  • TauroX
    • Dec 2024
    • 16
    • Ukraine
    #61
    Good day. Please help me figure this out. I can't defeat this notebook. I've tried a million different combinations. If I understand correctly. I need to break the main BIOS so that the EC is rewritten at the moment of the first turn on. I delete almost all information. It doesn't require a password when logging in. But I can't reset the security settings to factory defaults. Maybe I can somehow delete them from the EC flash drive? Please help me with advice.
    • rex98
      • Feb 2023
      • 1280
      • Mandaue CEBU, Philippines
      #62
      Originally posted by TauroX
      Hello. Please help unlock the BIOS. hp elitebook 830 G9
      SN#5CG3026WZX
      here thank you for your patience.
      first boot press f10 apply factory defaults and exit.
      use BCU
      here's your DMI:
      Serial Number: 5CG3026WZX
      Product #/SKU: 479Z1AV
      CT Number: PMYET00WBHL043
      Description: HP Elite x360 830 13 inch G9
      BuildID: 22WWWPBZ601#SABD#DABD
      Feature Byte: 476J6S6b7B7H7M7R7W7maBaEapaqauawbVcAd6eMfPfXguhKhkj4jhk8mEmVn7nVngpDpVpWpnpqprqjqz.7f
      MAC Address : 7C:4D:8F:36:C9:66​
      • TauroX
        • Dec 2024
        • 16
        • Ukraine
        #63
        use BCU
        here's your DMI:
        Thank you very much for your response. But the problem is still not solved. Moreover, now when loading the system it still hangs on the logo every other time. And the BIOS update does not install.Click image for larger version
ID:	3545022​At the first boot it gives this message. Is it maybe because of different versions of BIOS and EC firmware? How to fix it?
          SMDFlea commented
          Editing a comment
          click continue, let the ME recover
      • TauroX
        • Dec 2024
        • 16
        • Ukraine
        #64
        Hello to all masters. Help. I can't solve the problem with Intel Smart Sound Technology OED. I flashed the original BIOS back. It doesn't help. I was able to remove the password only by flashing someone else's unlocked BIOS. Then I returned mine back. Maybe someone has encountered and solved this problem. Please advise.
        • TauroX
          • Dec 2024
          • 16
          • Ukraine
          #65
          I have a suspicion that someone has already tried to unlock the laptop. I did not immediately check whether this error was there before all the manipulations. I am attaching the BIOS and EC firmware. Maybe someone who knows will see what is wrong?
          • danidanniiii
            • Jun 2024
            I've had similar issues on Dell laptops when flashing a different bios, i believe something in the bios is paired to the audio chip. Idk of a fix but you can go to device manager and "update" the driver to the MS audio driver and sound will work, you can also use a group policy to prevent it from updating itself (which it will if you just uninstall it)
            • VirVir
              • Apr 2024
              • 16
              Originally posted by Kippykip
              Re: Help unlock HP 830 g9
              Ah yes, this that stupid Audio Calibration data thing on some newer models. You can't edit it via the BIOS menus like the feature byte etc, only that UEFI proprietary tool that HP uses internally where you can calibrate it.
              But alternatively you can edit more CMOS string values manually using a USB EFI shell with the "UefiBiosConfig.efi" tool.
              If it's similar to va "HP EliteBook 860 16 inch G9 Notebook PC" you can try my personal dumped calibration data for the audio chip. (Hope it doesn't screw it up)
              Anyway make a bootable USB EFI Shell, extract the zip into the root of the USB. Navigate to EFI\Boot and copy my dumped cirruscalibrate.txt into there.
              Then boot into your USB EFI Shell (might need to turn off secure boot).
              Make sure you navigate to the USB drive then go to EFI\Boot
              Code:
              UefiBiosConfig -getconfig=cirruscalibrate.txt
              You can also dump your existing config using:
              Code:
              UefiBiosConfig -getconfig=cmosdump.txt
              Edit it in notepad or using the edit command, then restore it with:
              Code:
              UefiBiosConfig -setconfig=cmosdump.txt
              If the error goes away and the audio fixes itself, then horray!
              If you get a red screen of death on reboot about some stupid programming mode, run this:
              Code:
              UefiBiosConfig -setconfig=lockmpm.txt
              Good luck
              Whoops I meant
              Code:
              UefiBiosConfig -setconfig=cirruscalibrate.txt
              like in the screenshot
              Couldn't edit the post a 2nd time haha
              KippyKip, you're a savior !!! This worked like a CHARM on my EliteBook 865 G9 ) After entering all the data for the BIOS, waited for the count down to get to 1 and accept my information but SURPRIZE ) "Cirrus discrete bla bla error" and was stuck like that for more than two days ( But than i've found this post and everything WORKED GREAT !!! Only one thing, deactivating Secure Boot it's a MUST not a Might. If you can update the zip file with Bootx64.efi would be great for beginners like me would be the BEST. Anyway, whoever get the error about Cirrus Discrete, should use with 100% confidence Kippy's solution . And if anyone know someone from HP that worked on the G9 models and up, please fell free to kick them in the nuts ) I mean, what the hell with all this sh*t??? Up to G8 models this didn't happen !! Once again, KippyKip, a million thanx to you! Take care and keep helping poor fellas !
              • bhteam
                • Jan 2016
                • 7
                • Bulgaria
                #68
                Can you please unlock my BIOS please?
                Serial: 5CG24211LW
                SKU Number: 757Y2EC#ABU
                • peste
                  • Dec 2016
                  • 12880
                  • ROMANIA
                  #69
                  Serial: 5CG24211LW
                  post full name and model,product number..
                  • bhteam
                    • Jan 2016
                    • 7
                    • Bulgaria
                    #70
                    Serial Number: 5CG24211LW
                    Product #/SKU: 757Y2EC#ABU
                    CT Number: PPLSA00WBH8723
                    Description: HP EliteBook 830 13 inch G9 Notebook PC
                    BuildID: 22WWWPAT602#SABU#DABU
                    Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAdpdq eMfPgSguhKjhk8mEmVmwn7nVngpDpFpVpqqjqz.aB​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11813
                      #71
                      • bhteam
                        • Jan 2016
                        • 7
                        • Bulgaria
                        #72
                        Worked like a charm. No password and bios is open. Exited MPM with BCU and added the audio calibration.
                        Thank you very much.
                        • supernoahj
                          • Aug 2025
                          Hi can someone please help me unlock my laptop bios.
                          Product Name: HP EliteBook 830 13 inch G9 Notebook PC
                          Product Number: 4B5S7AV
                          Software Build Number: 22WWWPBZ601#SABA#DABA
                          Serial Number: 5CG25121HV
                          Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEn7nVngpDpFpVpnpqprqjqz.Hq
                          • azozexd
                            • Sep 2019
                            • 50
                            • Maroc
                            #74
                            Hello freind i have HP Elite x360 830 G9 2-in-1
                            i need à clean bios backup me region
                            the laptop hase bios password someone try to unlock it but not with the original backup Hé corrupte the original EC+MAIN BIOS
                            NOW LAPTOP IS WORKING BUT LATE DISPLAY AFTER 1 OR 2 MIN
                            PLEASE SOMEONE SEND ME A CLEAN ME BIOS THANK YOU
                            • peste
                              peste commented
                              Editing a comment
                              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                          • peste
                            • Dec 2016
                            • 12880
                            • ROMANIA
                            #75
                            post S/N, full name and model, motherboard model, product number,etc.
                            post the contents of the bios chip even if it is corrupted..
                            • azozexd
                              • Sep 2019
                              • 50
                              • Maroc
                              #76
                              THANK YOU
                              SN: 5CG3361NFD
                              prodID : 6W5Y3UC#ABA
                              HP ELITE X360 830 G9 2-IN-1
                              laptop work without original bios but probleme is late display i need new bios with clean csme region
                              THIS BACKUP NOT ORIGINAL
                              • azozexd
                                • Sep 2019
                                • 50
                                • Maroc
                                #77
                                use BCU
                                here's your DMI:
                                Hello brother any one upload tools to clean me region for the new génération laptop
                                what is the version of flash image tool to read bios of 830 G9 2-in-1
                                  HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:50 AM
                                  HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:20 AM
