Help unlock HP EliteBook 830 G9
  • plexuz
    • Jul 2016
    • 5
    • NL
    Re: Help unlock HP 830 g9
    Thank you for the good explanaition. Will try it and give you a update
    • plexuz
      • Jul 2016
      • 5
      • NL
      Thank you. It worked
      Originally posted by Kippykip
      Ah yes, this that stupid Audio Calibration data thing on some newer models. You can't edit it via the BIOS menus like the feature byte etc, only that UEFI proprietary tool that HP uses internally where you can calibrate it.
      But alternatively you can edit more CMOS string values manually using a USB EFI shell with the "UefiBiosConfig.efi" tool.
      If it's similar to va "HP EliteBook 860 16 inch G9 Notebook PC" you can try my personal dumped calibration data for the audio chip. (Hope it doesn't screw it up)
      Anyway make a bootable USB EFI Shell, extract the zip into the root of the USB. Navigate to EFI\Boot and copy my dumped cirruscalibrate.txt into there.
      Then boot into your USB EFI Shell (might need to turn off secure boot).
      Make sure you navigate to the USB drive then go to EFI\Boot
      Code:
      UefiBiosConfig -getconfig=cirruscalibrate.txt
      You can also dump your existing config using:
      Code:
      UefiBiosConfig -getconfig=cmosdump.txt
      Edit it in notepad or using the edit command, then restore it with:
      Code:
      UefiBiosConfig -setconfig=cmosdump.txt
      If the error goes away and the audio fixes itself, then horray!
      If you get a red screen of death on reboot about some stupid programming mode, run this:
      Code:
      UefiBiosConfig -setconfig=lockmpm.txt
      Good luck
      Whoops I meant
      Code:
      UefiBiosConfig -setconfig=cirruscalibrate.txt
      like in the screenshot
      Couldn't edit the post a 2nd time haha
      • Zibbo
        • Mar 2017
        • 203
        • Zimbabwe
        Hi, I kindly need help with unlocking this file
        • hoaca388
          hoaca388 commented
          Editing a comment
          Serial number ?
        • 21204
        RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
        You MUST:
        • Zibbo
          • Mar 2017
          • 203
          • Zimbabwe
          Model: HP Elitebook 830 G9
          SN#: 5CG31141D5
          • hoaca388
            Badcaps
            • Jan 2022
            • 11902
            #26
            SN#: 5CG31141D5
            CCCC
            • mac2sell
              • Aug 2017
              • 64
              • Italy
              #27
              Hp elitebook 830 G9 bios password please
              SN: ​5GC23146RZ
              • minhdigital
                • Nov 2022
                • 758
                • Vietnam
                #28
                SN: ​5GC23146RZ
                Send to you
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11902
                  #29
                  SN: ​5GC23146RZ
                  Unlocked
                  • mac2sell
                    • Aug 2017
                    • 64
                    • Italy
                    #30
                    Originally posted by minhdigital
                    Send to you
                    Thanks works perfectly
                    • stars-n-dust
                      • Apr 2019
                      • 59
                      HP Elitebook 830 G9
                      SN: 5CG3091FPG
                      Please remove BIOS password
                      • alfredposadas09
                        • Aug 2020
                        • 343
                        • Philippines
                        #32
                        Originally posted by stars-n-dust
                        HP Elitebook 830 G9
                        SN: 5CG3091FPG
                        you get the wrong chip .. read the chip near cpu
                        • stars-n-dust
                          • Apr 2019
                          • 59
                          Second chip
                          • rex98
                            • Feb 2023
                            • 1281
                            • Mandaue CEBU, Philippines
                            #34
                            Second chip
                            IDK i can't upload directly. so i posted a link instead.
                            only flash this main do not touch the EC.
                            first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
                            you can permanently disable absolute in BCU. Use BCU to fill these DMI info:
                            Serial Number: 5CG3091FPG
                            Product #/SKU: 4B5S1AV
                            CT Number: PPLSA00WBHS283
                            Description: HP EliteBook 830 13 inch G9
                            BuildID: 22WWWPBT601#SABU#DABU
                            Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEn7nVngpDpFpVpqqjqz.F4
                            MAC Address : 7C:4D:8F:F4:6A:7B
                            Badcaps Electronics Repair Forum & Schematic Search
                            • stars-n-dust
                              • Apr 2019
                              • 59
                              MAC Address : 7C:4D:8F:F4:6A:7B​
                              No display, fan spins at full speed.
                              • m.sabry2110
                                • Oct 2017
                                • 129
                                • egypt
                                #36
                                try
                                SerialNumber:5CG3091FPG
                                ProductConfigurationID:4B5S1AV
                                Board CT Number:PPLSA00WBHS283
                                Name:HP EliteBook
                                ProductName:HP EliteBook 830 13 inch G9 Notebook PC
                                FeatureByte:476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEn7nVngpDpFpVpqqjqz.F4
                                BuildID:22WWWPBT601#SABU#DABU
                                NetWork Mac Address :4D-8F-F4-6A-7B-7C
                                • stars-n-dust
                                  • Apr 2019
                                  • 59
                                  Originally posted by m.sabry2110
                                  try
                                  Name:HP EliteBook
                                  Sorry, can't test and report. Laptop is dead.
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    #38
                                    try
                                    • hammad Zaheer
                                      • Aug 2019
                                      • 5
                                      • Pakistan
                                      #39
                                      830 g9 unlock please
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11902
                                        #40
                                        Missing serial number included when requested.
                                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:50 AM
                                          HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
