6-71-NH5P0-D02 Bios Dump
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    Hi.
    Does any one have a Gigabyte G5 laptop / board 6-71-NH5P0-D02 (Clevo) bios dump?
    Thank's...
    • 22293
    Re: 6-71-NH5P0-D02 Bios Dump
    Originally posted by ZOrd_Z
    Hi.
    Thank's...
    Have you checked for bios downloads at gigabyte support
    • maksimthuk
      • Jan 2012
      • 23
      • Україна
      • javieromex
        • Apr 2016
        • 85
        • México
        Anyone can help with EC Bios?
        I need to flash IT5570E after previous one shorted.
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          post S/N, full name and model, motherboard model, etc.
          post the original contents of the bios chip..(main)...
          • javieromex
            • Apr 2016
            • 85
            • México
            Hello.
            • MB: 6-71-NH5P0-D02
            • SN: Sticker removed on case and I was not able to find it on the main bios
            • Model: Gigabyte G5 KC (Again, sticker removed but I am 90% sure thats the model).
            • Main bios attached
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              Hello.
              try..
              • javieromex
                • Apr 2016
                • 85
                • México
                try..
                Thanks, just checked and no luck.
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Gabrielnms
                  Need GigaByte GA-Z77M-D3H rev 1.0 dump bios
                  by Gabrielnms
                  I’ve had this motherboard Gigabyte GA-Z77M-D3H rev1.0 since 2013, and now my PC turns on, runs the CPU fan for a few seconds, and then shuts down. I tried clearing the BIOS by jumping the pins, bypassing the BIOS chip, and even resoldering it, but the problem still persists. A friend of mine recommended this forum and said that the members here might be able to help me, since I could recover my PC using an EEPROM programmer if I can get the correct BIOS .bin file.
                  I’d really appreciate it if someone could help me find or share the right BIOS file for...
                  11-12-2025, 11:52 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
