m1205bfp mb-v1.2 bios dump needed
  • warg6
    • Feb 2017
    • 8
    • eu
    Hello.
    I have a cheap, no-name windows tablet in hand.
    It was working until I got into the secure boot options.
    Now, it turns on but won't boot; no picture, just backlight.
    I can't get into the BIOS. I think it freezes right after it is turned on.
    I attached the original dump.
    Thanks in advance.
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: m1205bfp mb-v1.2 bios dump needed
    Originally posted by warg6
    Hello.
    Thanks in advance.
    Try this file, it could works.
    all donations are welcome,
      • 22284
      Hello.
      Thanks in advance.
      some tablets have a way to get into the bios settings or a menu. Try pressing volume up or down,or both together and holding it while pressing the start button
        • 22284
        cleaning the TXE won`t help , it would need the NVRAM clearing or invalidating if he can`t get into the bios settings
        • warg6
          • Feb 2017
          • 8
          • eu
          I tried all the button combinations. I also tried shorting the pins.
          • warg6
            • Feb 2017
            • 8
            • eu
            I tried, but it didn't work. It's still the same.
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              i tried, but it didn't work. It's still the same.
              post serial number or model number clear sticker image
              • hardware1
                • Sep 2021
                • 2949
                • N/A
                Understood
                • warg6
                  • Feb 2017
                  • 8
                  • eu
                  I only have board code: m1205bfpw mb-v1.2 201507131
                  I'm not sure about the brand/model. I think it's Dexp Ursus Z210.
                  • warg6
                    • Feb 2017
                    • 8
                    • eu
                    I just got a BIOS dump from an identical working mainboard, but it didn't work. Could someone clear the ME region? Thank you.
                    • Itechin
                      • Jul 2023
                      • Türkiye
                      I have same problem with my tablet, could you solved the problem?
                      Unfortunately I couldn't solve the problem.
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • James Maxwell
                        HP DM1-4000er Bios Dump needed
                        by James Maxwell
                        I badly need bios dump for HP DM1-4000er,
                        Model: HP DM1-4000er
                        Motherboard: DA0NM9MB6D0 REV.D
                        Product: QJ490EA#ACB
                        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                        10-28-2024, 05:38 PM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • ArkzG
                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                        by ArkzG
                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                        What I currently have available:
                        - Model: FA506NF (2021)
                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                        - Tools: CH341A programmer ready to use
                        Does anyone have either a clean 2MB .bin dump of this model,...
                        09-26-2025, 09:34 PM
