m1205bfp mb-v1.2 bios dump needed
  • warg6
    • Feb 2017
    • 8
    • eu
    Hello.
    I have a cheap, no-name windows tablet in hand.
    It was working until I got into the secure boot options.
    Now, it turns on but won't boot; no picture, just backlight.
    I can't get into the BIOS. I think it freezes right after it is turned on.
    I attached the original dump.
    Thanks in advance.
  • hardware1
    • Sep 2021
    • 2939
    • N/A
    Re: m1205bfp mb-v1.2 bios dump needed
    Originally posted by warg6
    Hello.
    Thanks in advance.
    Try this file, it could works.
    all donations are welcome,
      • 21133
      Hello.
      Thanks in advance.
      some tablets have a way to get into the bios settings or a menu. Try pressing volume up or down,or both together and holding it while pressing the start button
        • 21133
        cleaning the TXE won`t help , it would need the NVRAM clearing or invalidating if he can`t get into the bios settings
        • warg6
          • Feb 2017
          • 8
          • eu
          I tried all the button combinations. I also tried shorting the pins.
          • warg6
            • Feb 2017
            • 8
            • eu
            I tried, but it didn't work. It's still the same.
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              i tried, but it didn't work. It's still the same.
              post serial number or model number clear sticker image
              • hardware1
                • Sep 2021
                • 2939
                • N/A
                Understood
                • warg6
                  • Feb 2017
                  • 8
                  • eu
                  I only have board code: m1205bfpw mb-v1.2 201507131
                  I'm not sure about the brand/model. I think it's Dexp Ursus Z210.
                  • warg6
                    • Feb 2017
                    • 8
                    • eu
                    I just got a BIOS dump from an identical working mainboard, but it didn't work. Could someone clear the ME region? Thank you.
                    • Itechin
                      • Jul 2023
                      • Türkiye
                      I have same problem with my tablet, could you solved the problem?
                      Unfortunately I couldn't solve the problem.
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • James Maxwell
                        HP DM1-4000er Bios Dump needed
                        by James Maxwell
                        I badly need bios dump for HP DM1-4000er,
                        Model: HP DM1-4000er
                        Motherboard: DA0NM9MB6D0 REV.D
                        Product: QJ490EA#ACB
                        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                        10-28-2024, 05:38 PM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Joluvillas
                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                        by Joluvillas
                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                        06-18-2024, 10:35 PM
                      • kodox
                        Asus ExpertBook B1400CB Bios Dump Needed
                        by kodox
                        need original bios dump, original bios has flashed by other technician before me.
                        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                        unit info:
                        Model: Asus ExpertBook B1400CBA-0711A1235U
                        S/N: R6NXNZ006657238
                        CN: 7F6F
                        Mainboard Code: B1500CBA R2.1...
                        08-16-2025, 12:20 PM
