820-4924 logic board BIOS winbond 25q64fv1q
  • ub6ib969
    • Jul 2010
    • 199
    hi everyone,
    need to reprogram bios however when the clips do not work as the just slide off when attaching. Removed bios from logic board winbond 25q64fv1q and soldered on to breakout board and getting the following using neoprgrammer. Any thoughts, am I doing something wrong?
  • ub6ib969
    • Jul 2010
    • 199
    Re: 820-4924 logic board BIOS winbond 25q64fv1q
    Anyone ?
    • ub6ib969
      • Jul 2010
      • 199
      up
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria πŸ‡§πŸ‡¬
        Originally posted by ub6ib969
        up
        First of all 25q64fv1q is not a I2C chip, but in your screenshot I2C is selected, should be SPI NOR 25xx, secondly you most probably didn't connect correctly the breakout board to the programmer, upload the screenshot of your breakout board with the chip in it connected to the ch341a. Most probably you've connected the breakout board in a 24xx position instead of 25xx. There is a silk screen printed on the ch341a board about this.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • ub6ib969
          • Jul 2010
          • 199
          Thank you for your help. I uploaded a picture. As per SPI rom it automatically gets selected when I β€œdetect”.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria πŸ‡§πŸ‡¬
            I don't see the dot marking the pin 1 of the chip in the photo, the rest looks OK. It is connected as it should be. Try selecting manually under IC tab ---> SPI NOR 25xx ---> Winbond ---> 25q64fv.
            You cant also try another software for the ch341a like Colibri and/or ASProgrammer.
              • 21272
              The GND pad under the chip might be touching some of the adapter pins, it isn`t a proper WSON8 adapter
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
                by Vesko356
                08-11-2023, 03:27 AM
