need bios HP Mini 2133
  • resistor83
    • Oct 2018
    • 127
    • Italy
    hello all, I need a dump of an HP Mini 2133
    motherboard: 6050A2227701 POWERB A04
    I have this problem (see photo) and I want to try to flash the bios
    Here my dump:
  • resistor83
    • Oct 2018
    • 127
    • Italy
    Re: need bios HP Mini 2133
    UPDATE: I updated the bios but the problem remains
    • resistor83
      • Oct 2018
      • 127
      • Italy
      UPDATE 2: reflow cpu and the problem is gone
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers šŸ˜€,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
        šŸ”§ Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        šŸ’€ Problem:šŸ˜…
        - Device shows ā€œAdministrator Passwordā€...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • greelidd
        K6604J Vivobook RTX 4070 BIOS Dump Request
        by greelidd
        Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
        Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
        09-01-2025, 06:14 PM
