Lenovo Ideapad 5 15ITL05 Bios File
  • danielgerman681
    • Aug 2025
    • 6
    • Mexico
    i find a section in my chip "F0 AB 83 20 9B 83 A0 99 30 90 90 74 16 09 E3 2D 0C 42 A0 61 32 D0 01 32 C3 EF 05 56 00 2D 0C 32".
    PF2L7LS2
      SMDFlea commented
      Editing a comment
      Thread merged.
  • danielgerman681
    • Aug 2025
    • 6
    • Mexico
    Hi, Looking for working dumps of these chips for Lenovo IdeaPad 5 15ITL05 (MTM: 82FG00VELM, S/N: PF2L7LS2, NM-D211 Rev 1.0):
    • Winbond 25Q80EWNIG
    • ATML45DB081D (EC)
    Main BIOS (25Q128) + 25R64 already flashed. These chips are new/empty.
    Any dump or source would help. Thanks!
    • peste
      peste commented
      Editing a comment
      post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • peste
    • Dec 2016
    • 13908
    • ROMANIA
    • ATML45DB081D (EC)
    post the contents of the bios chip even if it is corrupted.. TYPE,etc.
    • danielgerman681
      • Aug 2025
      • 6
      • Mexico
      I’m currently working with an Adesto AT45DB081D SSU chip that I’m trying to read and write using a CH341A programmer. As many of you know, this specific DataFlash device is not natively supported by most CH341A software, which complicates the process.
      I would like to ask if anyone here has successfully managed to add this chip definition to AsProgrammer (or any other CH341A-compatible software) and if so, how they handled the custom read/write commands. Any guidance or working configuration would be greatly appreciated.
      Just to clarify my situation:
      I had a serious issue with my iOS BIOS chip, because some so-called “technicians” injected incorrect data into it and didn’t make a proper backup of my original BIOS. Because of this, I spent an entire day researching and was able to gather a lot of the required information.
      As I mentioned in a previous post, I needed to reconstruct the DMI region in order to restore the original system data. However, I don’t know exactly how the DMI region should be rebuilt.
      For reference, I’m attaching the following BIOS files:
      Attached BIOS files:
      1. FHCN78WWD Decrypted.bin – This file contains the BIOS already flashed with the data I currently have. This is the one I plan to use, as it reflects the state I currently have.
      2. FHCN78WWD Encrypted.bin – This file is the encrypted BIOS, the one that is read when the computer is powered on. I hope it is correct.
      3. Backup BIOS.bin – This is a copy of the computer after it was handled by the so-called technicians. The data found in this file was injected and is obviously not correct.
      Examine the decrypted file first to understand the current state of the BIOS. Keep both encrypted and Backup BIOS files as safe backups before performing any writes or modifications. zz0.0o1vnmz5752zz
      Any help from those of you with experience in this area would be greatly appreciated.
      • techsite
        • Jul 2023
        • 9
        • philippines
        need help may laptop says no hard drive...itried replace nvme and ssd and disable vmd in bios
        Lenovo Ideapad 5-15ITL05 Laptop
        HS45A/HS55A
        REV1.0
        NM-D461
        HERE IS MY BIOS FILE
        • peste
          • Dec 2016
          • 13908
          • ROMANIA
          #26
          HS45A/HS55A
          REV1.0
          NM-D461
          try post #10..
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
            Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook 5 Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 15ITL05 boardview and IdeaPad 5 15ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 04:10 AM
          • pcwhiz24
            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
            by pcwhiz24
            Model: Lenovo IdeaPad 3 14ADA05 81W0
            S/N: PF2BZS7D
            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
            I already have a CH341A programmer...
            04-07-2025, 07:10 PM
          • Jk KIM
            Lenovo Ideapad 5 15ITL05 Bios File extract
            by Jk KIM
            Hi
            I need to extract bin file from bios update file which downloaded at Lenovo web site.
            Pls extract bin file from exe file...
            I attached exe file!
            Thx!...
            02-03-2023, 07:40 AM
