HP Spectre 14-cb101np Fix bios please
  • NPIRES
    • Oct 2012
    • 20
    • Portugal
    Hi all
    have a hp 14-cb101np with mb. DA0P9KMB6C1 rec C, that boots with black screen. Flashed a bios found on the forum and it boots, but without SSD flash detected.
    Then flashed HP bios via winkey + B,and it now detects SSD, but windows crashes after intel vga driver install. Also no audio.
    Can someone please have a look at my original bios, please ?
    TIA
    Nelson
  • peste
    • 13451
    • ROMANIA
    Re: HP Spectre 14-cb101np Fix bios please
    Originally posted by NPIRES
    Hi all
    TIA
    Nelson
    try post#4
    https://www.badcaps.net/forum/showthread.php?p=1039213
    • NPIRES
      • Oct 2012
      • 20
      • Portugal
      First, thanks for your help.
      I've copied the memory regions (DMI 3C7000-3C70FF & KEYWIN 3C5000-3C503F) from my old bios to one pointed, and i have the same problem. (Can't install Intel vga driver, no audio & computer crash on shutdown). I see in bios screen that some info is missing,(feature byte, for ex.) can it be the source of my problems ?
      TIA
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        Hi all
        TIA
        Nelson
        Try this one, it's the Latest Virgin Bios from HP with your DMI and Windows Key.
        all donations are welcome,
        • NPIRES
          • Oct 2012
          • 20
          • Portugal
          Thank you. With this i have feature byte back in bios. Sadly the vga, audio & shutdown problems remain. So there must be some other problem with the board.
          Thank you all for your time.
          • mkdj
            What should I do after having flashed a BIOS?
            by mkdj
            Dear all,
            I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
            Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
            09-09-2025, 09:45 AM
          • Loli Popu
            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
            by Loli Popu
            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
            12-13-2024, 03:28 AM
          • drux
            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
            by drux
            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
            These models have AMI/Aptio BIOS.
            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
            11-03-2024, 01:18 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
