Need clean bios for a1398 i believe 2015 here is original bios backup
  • irepair559
    • Dec 2022
    • 134
    hello so i have a a1398 9 beeps i think its bios.. took out chip and did backup here it is.. dont know what emc it is bc the back cover isnt original .. its a1398 2015 i believe and board number 820-00163-a attached is the orignal efi dump
  • lint4u
    • Nov 2013
    • 123
    • lint4u
    Re: Need clean bios for a1398 i believe 2015 here is original bios backup
    Try this
    • irepair559
      • Dec 2022
      • 134
      it says file is larger then the ic?
      • irepair559
        • Dec 2022
        • 134
        i changed to 16mbyte/128mbit since chip is 16mb , is that ok? it flashed fine and no errors.. But i put it back on the board and no beeps now but just black screen and fans come on for 10 sec or so and then go off. will bloated battery cause no boot ? i tried unplugging battery and just leave charger and still same thing.. tried without ssd same issue. I did solder the chip backwards the first time lol will that damage the chip? i put it back on the reader and read it fine. im assuming the ic is good?
        • lint4u
          • Nov 2013
          • 123
          • lint4u
          hi There
          That file from the original,
          pls check the hardware for any corrosion or swap the bios IC from the others boards
          • irepair559
            • Dec 2022
            • 134
            it worked after i choose 8mbyte/64bit
            • irepair559
              A1398 2015 9 beeps ? Efi bios ?
              by irepair559
              hi i have a macbook pro 15 i believe 2015 a1398 from the looks of the bios chip and board layout. Well it has 9 beeps and doesnt turn on..ive heard it the efi bios chip? is there preprogramed chip that i can buy or do i have to reprogram the ic ? i did buy a efi reader and bios chip that looks little diff ( has legs like for the 2014 a1398 efi ) the one i have is newer flat type smd ....
              01-21-2023, 01:54 PM
            • DiddiAb
              BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
              by DiddiAb
              Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
              I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
              03-11-2023, 03:15 AM
            • Chris_stand
              Clevo PD50PNN won't boot after BIOS Backup
              by Chris_stand
              i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
              At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
              Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
              But the...
              04-28-2023, 03:08 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
