Lenovo IdeaPad S145-15IWL 81MV need bios repair
  • Japanac
    • Aug 2014
    • 94
    • Serbia
    Lenovo IdeaPad S145-15IWL 81MV need bios repair,When I connect the charger from the laptop and try to turn on the laptop, nothing happens, I take out the CMOS battery, wait a few seconds and turn on the CMOS battery again, I connect the power supply to the laptop, it turns on by itself, the logo appears, the post flashes, the LED on the laptop's ,power button does not allow me to F2 to access the bios settings, I can turn off the laptop only if I pull out the charger connector from the laptop, turn it on again and the laptop does not respond to the power button, it turns on only if I turn off the cmos battery again, the voltage is always 5V and 3.3V
  • peste
    • 12859
    • ROMANIA
    Re: Lenovo IdeaPad S145-15IWL 81MV need bios repair
    search the site and you will surely find what you need..
    • mximiliandz
      help bios lenovo ideapad s145-14iil type 81w6
      by mximiliandz
      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
      06-20-2025, 06:50 AM
    • jendkkd jeje
      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
      by jendkkd jeje
      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
      10-11-2024, 03:12 PM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      Today, 03:01 PM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • grimacelord
      by grimacelord
      Hello there.
      History:
      03-15-2023, 03:29 PM
