HP hp zbook firefly 14 g8
  • volinakis
    • Jan 2021
    • 2648
    • N/A
    #41
    Re: HP hp zbook firefly 14 g8
    Originally posted by kudo623
    Firefly 14 G8 need unlocked
    a donation to forum will be very welcome ...
    • kudo623
      • Aug 2022
      • 53
      Hi Thanks but same symptoms solid on caps LED
      The chip probably went bad after numerous attempts
      I'll have to scrap this one and work on another
      Thanks!
      • kudo623
        • Aug 2022
        • 53
        Here is a Firefly 14 G8 locked bios bin
        Please unlock for me. Thanks!
        • volinakis
          • Jan 2021
          • 2648
          • N/A
          #44
          Thanks!
          check if chipset is solder properly.
          • volinakis
            • Jan 2021
            • 2648
            • N/A
            #45
            same steps as previous.
            board CT: PKUHE00WBFS8M1 (it should be on a label from motherboard)
            • kudo623
              • Aug 2022
              • 53
              Thank you that worked!
              • volinakis
                • Jan 2021
                • 2648
                • N/A
                #47
                it also should work the other one, check if you can read bios chipset with programmer, maybe chipset is bad.
                • kudo623
                  • Aug 2022
                  • 53
                  Hi That chip was so brittle it cracked
                  I might try again if I can find another chip
                  Anyway I got another Firefly 14 G8 for unlocking
                  if you can help me with that, Thanks!
                  • volinakis
                    • Jan 2021
                    • 2648
                    • N/A
                    #49
                    board CT: PKUHE00WBFS4IP
                    • kudo623
                      • Aug 2022
                      • 53
                      I was able to get into the BIOS and reset to factory settings,
                      then put the DMI and the counter counted down to zero
                      then I tried to enter the BIOS it was locked again?
                      What happened?
                      • volinakis
                        • Jan 2021
                        • 2648
                        • N/A
                        #51
                        What happened?
                        you forgot the drill:
                        RESET BIOS to factory defaults, save, restart and password will go on.
                        • kudo623
                          • Aug 2022
                          • 53
                          That's possible. Thanks
                          I'll try again.
                          • kudo623
                            • Aug 2022
                            • 53
                            It works now thank you!
                            there was a message when I first got into the BIOS that I got before regarding the ME region being changed and if I wanted to restore it? I let the timer time out and did not choose to do that. Not sure if that has any bearing on anything?
                            Just a note: I found that these Winbond W25Q256FV 32MB chips in these boards will break down the more you heat them up or overheat them. They will eventually become brittle. I try to use the least amount of heat that will remove them or solder them to the board. What seems to break down first are the metal contacts that solders onto the motherboard.
                            Anyway, I had to get another chip as this one was broken down.
                            • kudo623
                              • Aug 2022
                              • 53
                              Firefly 14 G8 need unlocked Thanks!
                              • alfredposadas09
                                • Aug 2020
                                • 343
                                • Philippines
                                #55
                                Re: HP hp zbook firefly 14 g8 25Q256 (32mb)
                                Originally posted by vesko356
                                due to a lack of donations, server free space at a critical level, and possible closure of bios requests
                                all donations are welcome,
                                click on this link to donate via paypal. <<<<<
                                every donation made will go towards server fees and maintenance costs.
                                hi vesko may i ask what is ur software that you use to unlock this bios?
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #56
                                  HxD
                                  https://mh-nexus.de/en/hxd/
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                  • alfredposadas09
                                    • Aug 2020
                                    • 343
                                    • Philippines
                                    #57
                                    Originally posted by SMDFlea
                                    And doing it that way keeps the windows key ?
                                    okay thanks
                                    • kudo623
                                      • Aug 2022
                                      • 53
                                      Please post 54 can someone please help me on this? Thanks.
                                      • kudo623
                                        • Aug 2022
                                        • 53
                                        Unlocked! Thank you!
                                        • kudo623
                                          • Aug 2022
                                          • 53
                                          Hello
                                          Got a Firefly 14 G8 need to be unlocked
                                          Please help
                                          Thanks!
                                            HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                            09-07-2024, 05:20 AM
                                            HP ZBook Firefly 14 G7 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly 14 G7 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Firefly 14 G7 boardview and Firefly 14 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 07:20 PM
                                            HP ZBook Firefly 15 G7 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly 15 G7 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Firefly 15 G7 boardview and Firefly 15 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
