Surface Pro 6 BIOS
  • jsmrepairs
    EXPERT
    • Apr 2017
    • 6
    Surface Pro 6 BIOS
    Hi
    I have a surface pro 6 and the bios IC was removed and a dump made by someone else it came to me to fix what issues the last person caused.
    I believe the dumps made may be corrupted and the Bios IC was then connected to the programmer wrong and is now dead and lost.
    I ordered a replacement from eBay pre-programmed and fitted it now the surface boots and works as it should, however, I don't have touch I have already dumped the new BIOS and done what was said in the
    "MS Surface no touchscreen after cleaning ME Firmware **FIX**" thread but it was already set correctly
    I have also tried a new screen but still no touch
    thanks for your help
    two dumps are attached
  • Emre Ryan
    • Sep 2024
    • 6
    • FRANCE
    Hi, did you resolved your problem ? i have a smilar problem and i need help please?
    i dont have the backup and i dont have the original ic so i bought a new ic on ebay but not programmed i can dump it with your file ?
    • FalconPunch
      Surface Pro X 1876 Bios corrupted
      by FalconPunch
      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
      08-09-2025, 03:56 AM
    • whelanm87
      ๐Ÿ›  Request: Verified BIOS + EC Dumps for HP Envy x360 15-fe0053dx (JPR50 LA-M794P Rev 1.0)
      by whelanm87
      Iโ€™m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. Iโ€™ll be posting my own backups for reference and comparison.
      ๐Ÿ” System Details
      • Model: HP Envy x360 15-fe0053dx
      • Product Number: 7HVO3UA#ABA
      • Build ID: 23WW2GQZ6D
      • Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
      • Motherboard SPS: N30979-ABA
      • LCD SPS: N49271-601
      • Date Code: 172380
      • Keyboard Type: 0
      • Feature Byte:
        3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
        hZnp.praepq0Md4qkdf
      ๐Ÿ”ง Chip Info
      • Main BIOS chip: Winbond W25Q128JVSQ
      11-16-2025, 05:26 PM
    • macabook
      ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
      by macabook
      Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
      ๐Ÿงฉ Initial Issue
      07-24-2025, 02:17 PM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • muhuruu
      Surface pro 4 bios request
      by muhuruu
      Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
      01-22-2024, 05:38 AM
