Acer a514-54 bios needed
  • hieu13pro
    • Jun 2023
    • 32
    • viet nam
    #61
    thank you very much
    • JTEK
      • Feb 2018
      • 48
      • Philippines
      #62
      Originally posted by qayyum786
      S.N:- NXA2ASP00D1301A39C3400
      Try
      Thanks the bios is working fine. But i still got the same BSOD problem I think this is a hardware issue
      • Luxian05
        • Mar 2024
        • 3
        • United Kingdom
        #63
        Working bios required for Acer Aspire 5 A514-54-51A6, NX.A68EK.004.
        NXA68EK0040500C6333400, SNID: 05005073934.
        I had to change the mobo and I am not sure if the numbers are still correct but the bios.bin of the new mobo is attached to this post. The laptop powers on but does not come on, so I can't check the new variant (if any).
        • peste
          • Dec 2016
          • 12952
          • ROMANIA
          #64
          Bios extracted from Acer website update for Aspire A514-54..
          DMI 568000 - 569FFF
          KEYWIN 5DA000 - 5DA03F​
          • Luxian05
            • Mar 2024
            • 3
            • United Kingdom
            #65
            Thank you!
            • p3k0nox
              • Aug 2014
              • 8
              • việt nam
              #66
              Acer Aspire 5 model A514-54
              My computer won't turn on. I tried uploading another file to the source but the logo hangs
              I hope someone can help, thank you
              S/N: NXA28SV0092061D2B33400
              SNID: 20611947534
              Part Number: NX.A28SV.009
              Board:LA-K093P
              FILE:​
              • peste
                • Dec 2016
                • 12952
                • ROMANIA
                #67
                SNID: 20611947534
                Board:LA-K093P
                FILE:​
                Try post# 64
                • p3k0nox
                  • Aug 2014
                  • 8
                  • việt nam
                  #68
                  Originally posted by peste
                  Try post# 64
                  it shows up on the screen but when booting into windows it hangs
                  • biet507
                    • Mar 2021
                    • 3
                    • Indonesia
                    #69
                    Please help me. I need BIOS file for my Laptop.
                    Acer Aspire 5
                    A154-54-3427
                    S/N : NXA23SN00312101C673400
                    NX.A23SN.003
                    N20C4
                    MB : FH5AT LA-K093P Rev 1.0 2020-12-30
                    Bellow is my BIOS Backup
                  • testaccgta
                    • Jul 2024
                    • 12
                    • Brazil
                    #70
                    TL;DR:
                    Acer Aspire A514-54G-54Y4 powering on and off in seconds after BIOS editing (no backup dump available); neither clean nor any of the BIOS files posted on this thread worked when re-flashing by 3rd-party IT assistant
                    SN: NXABBAL002131004329Z00
                    SNID: 131001074935
                    Model Number: N20C4
                    Motherboard: FH5AT LA-K092P
                    ------x------
                    Hi, everyone.
                    I would like to request some assistance here. Please bare in mind that this post may not be in the correct section, so I'd really appreciate it if moderators could instruct me on where this should be posted instead.
                    About 2 weeks ago, I managed to brick my laptop BIOS by trying to unlock the Advanced Menu on Acer's latest v1.34 BIOS for my A514-54G laptop.
                    At first, my laptop simply wouldn't POST, as the LED indicator would only light for about 5 seconds and then would shut off. I tried re-flashing the clean BIOS from Acer's support website through their Recovery Method (USB Stick alongside Fn+Esc when booting up), which only led to my laptop spinning fans at max and no display shown.
                    Further, I decided to have my laptop sent to an IT assistant here in my country (Brazil) to re-flash the BIOS through a programmer, as at the time I didn't have that. This, however, led to no avail, and the IT technician tested literally every single BIOS file posted on this thread, and even a clean v1.34 BIOS from Acer's support website, only resulting now in the first issue of powering on and off after a few seconds back again.
                    Unfortunately, he didn't make a backup of the corrupted BIOS when doing so, so I wouldn't have the 16MB file available for your checking. Nonetheless, as I was doing these moddings in the BIOS and flashing through FPTW tool, I do have an 11MB modded BIOS file (perhaps that's what a partial BIOS image would be called of) that I managed to secure a backup for, which apparently holds some of my laptop's DMI info, if I'm not mistaken.
                    Please note that I'm a complete newbie in this area, and based on what I could gather both on Badcaps and on some other forums, I ended up searching my SN using the Find Tool in HxD Editor on this 11MB file, which was on bit 68000 (hence the 50000 bytes difference from @peste's #64 post here mentioning DMI info on 568000 - 569FFF padding), so I was wondering if, now that I have my soldering kit and programmer set, I should just copy block 68000 - 69FFF from this 11MB backup to a clean v1.34 BIOS and that should do the trick, or if there is something awry here that I can't grasp yet.
                    I should also mention that this 11MB backup file was the one flashed that got my laptop working with Advanced Menu unlocked before I ended screwing things up by changing a bit through RU.efi BIOS shell live editing on VarStore:0x1234 (SystemConfig UEFI variable VarName:0x1A9) when attempting to make the undervolt and overclocking options appear instead of hidden/greyed out in the Advanced Menu). So, this 11MB backup file was indeed working fine as my BIOS running, though I don't know if copying this whole DMI block I mentioned would be enough as there are some bits (e.g., 680EB - 680FA bits) which are filled instead of blank FF bits as there would be on a clean BIOS or on some BIOS files posted here that I've ran through in HxD Editor. Thus, perhaps the DMI info actually only goes to a certain row instead of all the way through 69FFF byte, TBH I have no clue as I don't even know how someone manages to find out that 568000 - 569FFF padding contains that in the first place. At this point, I'm just clueless at what I should look for as corrupted or corrected paddings/sections/bytes/bits/any other term.
                    Currently, I'm facing exactly what @dnytwaryors described on post #23 and they apparently managed to get their laptop booting up and POSTing either through @kalilinux25's #44 post file or @hoaca388's #48 post file, which apparently my IT technician already tried with those but with no luck. I also wonder if I need to re-flash both my BIOS SPI and Super I/O (ENE KB9052) chips as per @kalilinux25 mentions on post #51 (that's why I even bought a ribbon cable to do some soldering on the keyboard's connector and have my CH341a programmer read and write that EC BIOS through that), or if that would only worsen the problem here due to in fact I had instead to check my motherboard's core voltages to see why the sudden shut off, without any need to re-flash EC, among any other possible issues which may not even be regarding flashing some ROM images.
                    Anyway, I'd really, really be glad if anyone could kindly help me with all this, as I'm going nuts already, and the lack of experience, even though having read through most beginner's guide on how to start on this whole new electronics world and digging through some forums' posts, hinders me so much that I can't seem to figure out any other way I could explain my issue here. I also make myself fully available for perhaps a Zoom call, regardless of time zones, if anyone would be kind enough to guide me through instead of typing (as I know typing can take a lot more of our time than just telling it out loud straight).
                    Thank you in advance, and hopefully I will manage to get things working with your help!
                    • minhdigital
                      • Nov 2022
                      • 758
                      • Vietnam
                      #71
                      Originally posted by testaccgta
                      TL;DR:
                      SNID: 131001074935
                      Model Number: N20C4
                      Send to you, good luck !!
                      • testaccgta
                        • Jul 2024
                        • 12
                        • Brazil
                        #72
                        Thank you very much for your help, minhdigital!
                        Unfortunately, I wasn't able to test this new image file you sent me right off the bat because when my repairing kit arrived, I noticed something odd with my motherboard.
                        That's when I realized that what might be really causing the problem was the lack of some mini SMD components (i.e., 0201 RCs and CCs) around the SPI IC chip, as per below:
                        All in all, I would like to thank you once again for your effort in sending me some BIOS files to test.
                        I've decided to order a new MB piece to replace mine altogether, as neither do I have the necessary equipment to solder such small components nor the skill for that either​ (wow, they're really teeny tiny 😅). It's unfortunate, as this could have only occurred because of some probably bad de-soldering and re-soldering process from the 3rd party IT assistant I had my laptop sent to in the first place for re-flashing the BIOS files from this thread when I didn't have my soldering repair kit yet.
                        Well, it is what it is... living and learning, but I can feel more reassured now that the problem wasn't in the BIOS files tested nor my unlocked BIOS one, but indeed something faulty in the MB.
                        • rayshine03121408
                          • Feb 2018
                          • 94
                          • Phillipines
                          #73
                          Hello Masters! Need Help with Acer A514-54 after BIOS Update Critical Battery Error always showing up when laptop turns on... i tried to change the batt but still same issue. TIA
                          Model: Acer A514-54
                          Boardmodel: FH5AT LA-K093P Rev.:1.0
                          S/N: NXA2ASP00D12319BE13400
                          • peste
                            peste commented
                            Editing a comment
                            post merged..
                        • michi.boy
                          • Jun 2020
                          • 17
                          • philippines
                          #74
                          Hello, need help!
                          Acer a514-54-344a
                          Problem: SSD not detected when reformatting, it shows no available drive. But in the Bios setup it shows, tried both NVME and Sata SSD.
                          SN: NXA2BSP00A230141FC3400
                          SNID: 23008242834
                          Model Number: N20C4
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11886
                            #75
                            Originally posted by michi.boy
                            Hello, need help!
                            Acer a514-54-344a
                            SNID: 23008242834
                            Model Number: N20C4
                            Aspire A514-54
                            • repaircentree
                              • Nov 2022
                              • 11
                              #76
                              hi, need help please, A514-54-53CY. Fault: turns on, no display. tried all the bios files available in this thread, now laptop turns on with display but stuck on acer logo. tried with different ssd still same, and not booting with windows 10 or 11 reinstallation usb. attached is original bios file which has no display. thanks
                              • repaircentree
                                • Nov 2022
                                • 11
                                #77
                                hi, need help please, Acer A514-54-53CY. Fault: turns on, no display. Now it turns on then off after a few second. thanks
                                • peste
                                  peste commented
                                  Editing a comment
                                  post merged..
                              • peste
                                • Dec 2016
                                • 12952
                                • ROMANIA
                                #78
                                Originally posted by repaircentree
                                hi, need help please, Acer A514-54-53CY. Fault: turns on, no display. thanks
                                post the S/N, the motherboard model, etc.
                                • repaircentree
                                  • Nov 2022
                                  • 11
                                  #79
                                  motherboard FH5AT LA-K093P
                                  SN: NXA4YEK0021380CE943400
                                  btw just tried my laptop with my original bios but now it turns on then off after a few second
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11886
                                    #80
                                    Backup fault.
                                    • EbrahimSiami
                                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                      by EbrahimSiami
                                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                      **What I have tried so far:**
                                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                      07-02-2025, 02:31 PM
                                    • NecroFlex
                                      Acer Aspire 1 A115-32-C28P BIOS needed please
                                      by NecroFlex
                                      I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                      I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                      I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                      02-11-2025, 08:51 AM
                                    • Wg188
                                      ACER Veriton Z4660G AIO bios help
                                      by Wg188
                                      I have an Acer veriton Z4660G all in one pc,
                                      Model: Z4660G-I5850H1 (VZ4660G_W)
                                      Need bios dump and schematic would save my life !
                                      to make a long story short I bought this all in one used
                                      with a broken lcd, with the objective of making a custom desktop out of it
                                      ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                      06-17-2023, 02:20 PM
                                    • tlindi
                                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                      by tlindi
                                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                      Ack
                                      Ack
                                      01-30-2025, 04:26 AM
                                    • totof
                                      Acer Aspire V3-372T-58TH Bios Dump needed
                                      by totof
                                      Hello
                                      I need the latest bios for Acer Aspire V3-372T-58TH (Intel Core i5-6200U Skylake).
                                      My computer start but screen remains black and boot loop every 10 seconds. All voltage seems good so it may be a corrupted bios (I hope).
                                      Model N15W8
                                      SN NXG7CEF006551013E46600
                                      MIHAWK MB 15208-2 BOARD
                                      448.06J05.0021
                                      MB NBG7C110035510009A6600...
                                      08-23-2025, 12:25 PM
