Acer a514-54 bios needed
Re: Acer Aspire 5 - FH5AT LA-K093P
It didn't detect the SSD because the other file wasn't clean.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello, Good Day,
If you have bios file for this laptop. I have my backup file but my EZP2019+ suddenly turning on & off. I don't think it is the complete file for it. I have tried many times but still the same. I also accidentally erase/wipe the file and now the bios is empty. My laptop have sign of power but suddenly off & no display.
Can anyone help me?
Thank you in advance.
S/N: NXA27SP00N14922C653400
SNID: 14914243734Attached FilesLast edited by dnytwaryors; 12-02-2023, 06:55 AM.Comment
Thanks for sharing bro. but its not working. I am using CH341A programmer now and i try it also in ezp2019+ still the same. It also error when I'm verifying the program.Comment
I tried all the bin files that posted here. My laptop got power and all but still no display. I used this file below thanks for this. Can anyone possible change the S/N written on this bin file?
I have this S/N can anyone replace it with mine.
S/N: NXA27SP00N14922C653400 SNID: 14914243734
​​​​​Model : A514-54-31WL
Board : Chuan Yi FH5AT LA-K093P REV 1 2021
Thanks in Advance.
Only S.N has been changedComment
When I first time using the programmer I used clip (Not effective) . Now im using desolder method and I tried many bios. Hope this one will work. Thank you for your effort sir. I'll feedback later.Comment
No sir I did'nt get display. but all the the power required is present like keyboard backlight,charging light & etc. only the display is not working. But in the file you have sent only power no lights present but merely 2 secs power off and then did not go back anymore. it is like the reaction of my backup bin file they the same.Comment
Try This new virgin bios extracted from acer support if still no image than chk your M-B
DMI @ 5648C0-569FFFAttached FilesLast edited by qayyum786; 12-17-2023, 10:01 AM.Comment
Sorry to ask sir how do I check the DMI ? Do I need to use hexeditor ?
Thanks for the file sir. I will try it later.Comment
Sir I program it and the reaction is still the same only power indicator and suddenly goes off. maybe because of not having a DMI ?Comment
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by NecroFlexI have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...-
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by cekconsg1 assassin Rev 1 bios dump - main and backup needed
main and backup ic dead so i cant post corrupt bios cause its 01 all over.
thanks-
01-23-2024, 03:26 AM -
- Loading...
