Hp elitebook 820 g3 bios
  • karl6
    • Feb 2023
    • 13
    • lyon
    Re: Hp elitebook 820 g3 bios
    hello, lapfix the fan starts and stops and the screen remains black you have a lead
    • hardware1
      • Sep 2021
      • 2948
      • N/A
      Here's your New Bios file, try it and let me know.
      Serial Number: 5CG8121Q1Z.
      all donations are welcome,
      • karl6
        • Feb 2023
        • 13
        • lyon
        it was the memory that was the problem, now it starts up fine and I always have the Bios asking for a password
          • 21845
          Try HP unlocker or RCUnlocker -> https://www.badcaps.net/forum/showpo...42&postcount=4
          • karl6
            • Feb 2023
            • 13
            • lyon
            hello, no reaction with your dump only 2 blinks
            • karl6
              • Feb 2023
              • 13
              • lyon
              #26
              Originally posted by SMDFlea
              hi, do you have the procedure?
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                It is already explained in the relevant topics. You don't expect someone to read it for you, do you?
                Become a Badcaps supporter
                Thanks to all supporters.​
                • karl6
                  • Feb 2023
                  • 13
                  • lyon
                  #28
                  Originally posted by lapfix
                  This a clean me of your bios
                  hello, your dump is ok it managed to start the pc but the bios always asks me for the password
                  • karl6
                    • Feb 2023
                    • 13
                    • lyon
                    #29
                    sorry, not easy to translate
                    • karl6
                      • Feb 2023
                      • 13
                      • lyon
                      #30
                      if there is a video on youtube?
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #31
                        https://www.badcaps.net/forum/showthread.php?t=98539
                        Is it that hard to translate a sentence from English to French?
                        Usage: Drag and drop .bin file to .exe file.
                        Code:
                        Utilisation : faites glisser et déposez le fichier .bin dans le fichier .exe
                        https://translate.google.bg/?hl=en&sl=en&tl=fr&text=Usage%3A%20Drag%20and%20drop%20.bin%20file%20to%20.exe%20file.&op=translate
                        • karl6
                          • Feb 2023
                          • 13
                          • lyon
                          #32
                          I used RCUnlocker but it does not work, black screen does not start
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #33
                            I have checked the file and it's OK, there's no reason for such a behavior, try again to program the chip, use verification, check the soldering. Should work.
                            • karl6
                              • Feb 2023
                              • 13
                              • lyon
                              #34
                              hi, it was a soldering problem, thanks for your help. a big thank you to the team
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #35
                                You see, as I told you everything will be fine. Besides, you learn something new for yourself, and in the future you will be able to solve such a problem on your own. Congratulations.
                                • alihomee
                                  • Dec 2012
                                  • 1591
                                  • malaysia
                                  #36
                                  after some times fan goes full speed with no post on screen ori file is attached
                                    • 21845
                                    Clean the ME firmware -> https://www.badcaps.net/forum/showpo...41&postcount=3
                                    • alihomee
                                      • Dec 2012
                                      • 1591
                                      • malaysia
                                      #38
                                      tried this method but no luck.....now notebook totally dead
                                      • alihomee
                                        • Dec 2012
                                        • 1591
                                        • malaysia
                                        #39
                                        anyone here to help as i am not so sure with the file and steps
                                        • hardware1
                                          • Sep 2021
                                          • 2948
                                          • N/A
                                          #40
                                          Here's your Clean BIOS, try it.
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • lap-top123
                                            Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                            by lap-top123
                                            HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                            Hp Elitebook 850 G8
                                            ProdID 52W98EC#ABD
                                            SN# 5CG1458XQ7
                                            Mac-address #1: 84:14:4D:2C:4B:5B
                                            UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                            Mainboard : 6050A3216701-MB-A01(A1)
                                            08-20-2025, 07:28 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
