Need bios for Hp 245 G7 hagrid-6050A2983601-MB-A02(A2)
  • nitish300
    • Jul 2019
    • 21
    • india
    i got a flash of back light then no display here is the backup file
    • 20888
    Re: Need bios for Hp 245 G7 hagrid-6050A2983601-MB-A02(A2)
    post the laptop serial number
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      here virgin bios extracted from hp support
      S.N-5CG908433T
      • nitish300
        • Jul 2019
        • 21
        • india
        sn:5cg908433t
        • Cronosmx
          • May 2023
          • Mexxico
          What worked for me is the following:
          I downloaded the file 084A2.rar provided by qayyum786 then i used the AsProgrammer_2.1.0.13_fix and flashed the bios with this file, once finished i was able to turn on the computer but i was getting an error every time the computer turned on, the next step was to create a USB recovery drive for my computer model, i went to the HP website and downloaded the Bios Firmware for my computer and created USB recovery drive, i went back to my computer and followed the following steps:
          1.- Turn off the computer that requires the BIOS recovery, and then wait 5 to 10 seconds.
          2.- Insert the USB flash drive with the BIOS file into an available USB port on the computer.
          3.- Press and hold the Windows key and the b key at the same time, and then simultaneously press and hold the power button for 2 to 3 seconds.
          4.- Continue to hold the Windows and b keys, but release the power button. You might hear a series of beeps.
          5.- The HP BIOS Update screen is displayed and the recovery began automatically to install the lattes firmware update.
          All the step you ca find them on the following link:
          https://support.hp.com/us-en/documen...820-3438449-16
          Once my computer was fixed i created a backup from the bios from my computer and uploaded maybe it will work for you too, My computer is an HP 245 G7.
          I hope it works out for you too.
          Have fun.
          • cokan kepo
            • Jul 2021
            • 50
            • Indonesia
            Thanks Cronosmx,your file is work 100%...
            • Sayidah
              • Dec 2023
              • 12
              • Indonesia
              Need bios hp 245 g7
            • alejandr2004
              • Dec 2024
              • COLOMBIA
              Hello. Can you help me please, need bios for HP 245 G7
              S.N: 5CG119OVMQ
              BIOS: Winbond 25Q128JWSQ
              • peste
                • Dec 2016
                • 12792
                • ROMANIA
                post the original content of the bios chip, even if it is corrupted..
                • yctugh
                  • Dec 2024
                  • 3
                  • australia
                  Hi everyone, thanks for the thread. I also need the bios for HP 245 G7.
                  S.N: 5CG9136SRL
                  BIOS: Winbond 25Q64FW​SIQ
                  The corrupted BIOS is attached.
                  It was my dumb error. I was experimenting with flashing and re-flashing the BIOS chip with a CH341A.
                  Didn't double check the dump. When I re-flashed, I got an error. Power is there but the screen is blank.
                  • yctugh
                    • Dec 2024
                    • 3
                    • australia
                    Apologies if this appears to be spam but I've solved my own problem.
                    I extracted the 084A0.BIN file from the HP BIOS tool and this worked for me without a hitch.
                    I have attached this to the post. I hope it helps someone else.
                    • abhorsen
                      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                      by abhorsen
                      Hey guys,
                      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                      07-06-2023, 10:22 AM
                    • survivalbloke
                      If I flash this bios file, will it just work, or does it need the ME cleaning?
                      by survivalbloke
                      I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
                      ENVY X360
                      15-ew0013dx
                      SN: CND2261KS3
                      Prod: 698V0UA
                      Board: LA-M021P Rev 1A
                      Chip# Winbond 25R128JVSN​
                      Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
                      10-09-2024, 08:40 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      Today, 05:12 AM
                    • iZakre
                      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                      by iZakre
                      Hello everybody!
                      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                      The thing is that I had installed TeamViewer and could log into the computer...
                      02-19-2023, 02:27 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
