MB Pro A1989, 820-00850-A tricky repair
  • BeertjeBas
    • Aug 2017
    • 6
    • Nederland
    Hello All,
    I want to thank all for submitting valuable information in this forum.
    So, at year end i want to share one of my experiences.
    My name is Gerard, 68 years old and repairing mostly Macbooks on a daily basis. It is a hobby i enjoy very much. Most of the repairs come from shops however.
    Yesterday i started with this 820-00850. It would not start after being in the carport for one night with high humidity wheather.
    The board was very clean and there was absolute no corrosion or other damage. ( I was not the first one to look at it)
    I found it had 20V on USB-C meter with fluctuation amps between 40 and 80 milliamps. This fluctuation came back on several places on the board. Even around the cpu although only millivolts.
    Checking the CD3215's i found that one of them did not show 1.1 volt. If voltage was connected to another CD3215 the voltage of USBC_TB_CC2 was fluctuating between 0.4 and 2.6 volts.
    So i replaced the bad CD3215.
    The board was booting ok. Put it in the chassis and it powered on. Could boot up and test everything. After 30 minutes i shut it down. After a new succesfull boot the fans started spinning at full speed. I let it run for a while and suddenly the fans stopped but the laptop kept running.
    Don't see this behaviour so often.
    After i shut it down, it would never start again.
    So a new repair started.
    First i checked the cd3215's because i saw same behaviour as at the beginning. 20V with fluctuating small current.
    Then i started measuring.
    I used the 820-01598 power-on sequence scheme.
    All was ok until i came at the NAND voltages. Input was ok. (voltages, SSD_PMU_Reset_L 1,8V , PMU_SYS_Alive 1,4V.
    There was no output from U9000.
    As this area was pristine i decided to reflow U9000 first.
    During the reflow i noticed there came some crap from underneath it.
    After cleaning and cooling down the board is running flawlessly now.
    Very happy with it.
    Now i came to the conclusion that U9000 really was the culprit.
    After replacement of the cd3215 it had been hot and would work for a while.
    That might lead to the conclusion that this board can boot and run and have 20V with a faulty CD3215 when its not the master.
    So i hope there will be, somewhere in the future, someone that will benefit from this little story.
    Wish you all a happy xmas and a very good 2023.
  • davis12
    • Nov 2012
    • 26
    • denmark
    Re: MB Pro A1989, 820-00850-A tricky repair
    thanks for sharing your experience!
    • Stephen
      A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
      by Stephen
      As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
      5.16V .47amp
      5.16V .47amp
      5.16V .47amp
      5.16V .04amp (this guy is the issue) (U3200)
      So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
      11-27-2023, 03:57 PM
    • Guest
      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
      by Guest
      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
      Observations...
      01-14-2025, 03:54 PM
    • gugutm
      a1989 820-00850 stuck at 5v 0.041a Help
      by gugutm
      I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
      long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
      of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
      01-04-2025, 09:35 AM
    • obelix24
      A1989 - replace SSD
      by obelix24
      I have one A1989 that have not internal LCD (there was water damage on LCD connector) but macbook itself was working fine.
      After some time it stoped working and starts in Recovery mode. When i try to restore in DFU it always fails with error : AMRestoreErrorDomain error 75 - Failed to handle message type StatusMsg (Missing data volume))
      Is it possible to just swap SSD from some other macbook ? (or it have some dependecies ? A1989 only, some special possition from donor to correct possition on my macbook ? or i can take any SSD chips from any other macbook (with T2) and put...
      05-11-2025, 01:53 PM
    • BMCappelletti
      Macbook Pro 2018 A1989 - Only 5V - Had PPBUS_G3H, not anymore
      by BMCappelletti
      Hi everyone.
      Macbook Pro 2018 A1989, board 820-00850.
      Only 5V on the meter, and around 250 mAmps drawn. Lots of dust on the sides, as usual. Cap CD308. right over CD3215 (UB300) was shorted. I did have PPBUS_G3H at 12.3V. measured on CC851, if I am not mistaken.
      Replaced CB308 with a cap from another board, with same specs. Now I don't have a short on it anymore, but neither PPBUS_G3H.
      When connecting the meter to the USB-C ports it keeps restarting, except on front port on the other side. And CD3215 close to it (U3200) gets hotter than usual. F3000 is the fuse with 5V...
      12-05-2025, 03:18 PM
