Macbook Pro 15" A1707 820-00928 no chime,no boot,no image
  • Aliseo
    • Dec 2022
    • 12
    • Italy
    Hello, I'm working on a 2017 15 inch macbook with motherboard 820-00928.
    Board is look good, no signes of liquid damaged.
    The motherboard takes 20V 1.1A (without battery) but it doesn't start, the trackpad works, caps lock doesn't light up, the fans spin and with an external monitor nothing is shown.
    I excluded the usb C area because it takes 20V, I measured the voltages on the big coil, I receive all the voltages, GPU and CPU heat up regularly
    PPVCORE_S0_GPU is 0.9V
    I tried to flash a new bios but the result is always the same.
    Any ideas or advice??
    Thanks to whoever will answer.
  • mon2
    • Dec 2019
    • 13835
    Re: Macbook Pro 15" A1707 820-00928 no chime,no boot,no image
    Post the exact voltage to ground for PPBUS_G3H and 3V3_G3H.
    • Aliseo
      • Dec 2022
      • 12
      • Italy
      Originally posted by mon2
      post the exact voltage to ground for ppbus_g3h and 3v3_g3h.
      ppbus_g3h= 12,61v
      3v3_g3h= 3,27v
      • dclass-pro
        • Dec 2022
        • 157
        • Italy
        Have you tried restoring the T2 in DFU mode with another macbook and Apple Configurator app?
        • Aliseo
          • Dec 2022
          • 12
          • Italy
          2017 machine haven't T2, i cannot go in DFU
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            ok ok have you checked if voltages PP3V3_S5 and PP5V_S5 are generated?
            • Aliseo
              • Dec 2022
              • 12
              • Italy
              PP3V3_S5 and PP5V_S5 are present
              • dclass-pro
                • Dec 2022
                • 157
                • Italy
                ok also check if there are:
                SPIROM_USE_MLB = 3.3V
                PM_PWRBTN_L = 3.3V
                PM_BATLOW_L = 3.3V
                S5_PWRGD = 3.42V
                PM_SLP_SUS_L = 3.3V
                SMC_BC_ACOK = 3.42V
                PM_SLP_S5_L = 3.3V
                • Aliseo
                  • Dec 2022
                  • 12
                  • Italy
                  PM_PWRBTN_L = 3.3V
                  PM_BATLOW_L = 3.3V
                  S5_PWRGD = 3.42V
                  PM_SLP_SUS_L = 3.3V
                  SMC_BC_ACOK = 3.42V
                  PM_SLP_S5_L = 3.3V
                  All voltage present
                  • nrjnapu
                    • Jan 2019
                    • 4
                    • Japan
                    I have a PC with exactly same symptoms and would like to know if you wer able to resolve it.
                    • mon2
                      • Dec 2019
                      • 13835
                      Does the unit use 20v to power the board?
                      What is the current draw? (You can use usb c meter)
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        I have A1706 with the exact same problem - Voltages may vary !
                        Keen on knowing the result.
                        • gugutm
                          Macbook Pro 15" A1707 820-00928-04 no chime,no boot,no image 19.92v 0.900a
                          by gugutm
                          Hi everyone
                          Please bear with me as I am not yet a pro with some of these issues. Trying to watch a lot of youtube videos and master myself but there are things which I cannot fix and would like to ask for a help from the pro people.
                          Got macbook a1707 board no 820-00928-04
                          It had a water damage on couple components, green staff corrosion,
                          C7680 ppbus _hs_oth3v3, tested for short I believe its okey red prob on ground, getting 2.512kilo om
                          C7251 ppbus_hs_cpu done the same and getting about the same, 2.506kilo om
                          U5400 some corrosion, I clear all this...
                          08-05-2023, 04:58 AM
                        • leonemax81
                          Macbook a1707 820-00281 Battery no Power
                          by leonemax81
                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                          08-23-2024, 09:24 AM
                        • sofles
                          Macbook a1707 2017 model 820-00928 GPU issue
                          by sofles
                          Hello there
                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                          11-21-2024, 05:25 AM
                        • baglaivlad
                          MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                          by baglaivlad
                          Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                          Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                          01-09-2024, 09:55 PM
                        • tommy97
                          Apple MacBook A1707 No Audio/Sound
                          by tommy97
                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                          I've also replaced U6300, but the problem persists.
                          Here are the current voltage readings:
                          • PPV18_S0: 1.8V
                          • R6402: 1V
                          • R6405: 1V
                          • R6403: 1V
                          • AUD_SPKRAMP_RESET_L: 1.3V
                          • PPBUS: 12.6V
                          03-10-2025, 11:22 AM
