Macbook 820-2610-A
  • lcdcaps1
    • Oct 2011
    • 322
    Macbook 820-2610-A
    Hi
    I have an 820-2610-A
    Board was working
    U7000 is removed and was in the process of rebuilding some pads around u7000 but then realised that there is a short on CHGR_PHASE.
    I confirmed this on L7030, pin 1 and I also have a short on PPVBAT_G3H_CHGR_REG_L confirmed on pin 2 on L7030 and on L7301 pin 1 there is a short (that would be because it is connected to pin 2 on L7030) but on pin 2, PPVBAT_G3H_CHGR_REG on L7301 it is shorted as well.
    If I remove the L7030 Coil the short is not there on CHGR_PHASE and the coil has continuity when tested out of the circuit. When I put the coil back the short comes back.
    I have removed F7040 and F7041 to see which side the short is but wanted
    The short is on pin 2,
    short to ground on pin 2 is 0.3 ohms
    removed fuses F7040 AND F7041,
    pin 1 PPBUS_G3H and pin 2 PPVBAT_G3H_CHGR_REG
    pin 1 of F7040 AND F7041 Is in the mega ohms
    I injected voltage on L7031 pin 2, started with 1v and 0.35amp
    and its drawing 0.34 amp
    I increased to
    1.50v and drawing 0.51 amp
    Nothing is getting hot
    My wires are only thing getting hot
    Please can any experts for these boards 820-2610 get in touch
    Thanks so much
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • Stephen
    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
    by Stephen
    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
    02-06-2025, 12:03 PM
  • adelfr2009
    HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
    by adelfr2009
    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
    09-28-2025, 10:21 PM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • aaronkatrini
    Help me find the short circuit on this WORKING Nvidia GTX1650
    by aaronkatrini
    Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
    Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
    04-18-2024, 03:15 PM
